Results 1 to 9 of 9
    Junior Member One Ring
    Feb 03 2017
    2011 Silverado, 2006 SV650, 1968 GMC pickup
    Halifax/Canada
    Crank - No Start
    2012 A4, 2.0L, manual transmission.
    Finished a K04 turbo install and got an IE K04 tune a couple weeks ago.
    Was running pretty good. I got a couple new errors soon after.
    Oil pressure regulating valve p164E (ordered, not installed yet)
    Intake manifold flap p2004/P2015.00
    Haven't replaced it yet. I can't see any obvious leaks.
    Could either of those cause a hard start?
    When I push the keyfob, the car cranks for a split second then stops. I can force it to continue by holding the key to crank.
    Help!?
    Dec 16 2017
    Oregon
    I would resolve all your errors first then determine if you have problems still. A lot of things on this engine are driven by oil pressure. The runner flaps are a known problem on these cars. I would take the IM off, clean all the carbon out, grease the actuator, verify the actuator works and see what you get. You are suppose to press the key fob in and hold it till the car starts.
    Feb 03 2017
    Halifax/Canada
    I ended up replacing the camshaft position sensor and the starter/function works correctly now. You do NOT have to hold the key fob to start. It was as I thought, that you push it momentarily, and the car attempts to start the car however long that takes.
    Unfortunately, I have thrown a bunch of parts at the car now and still haven't made much headway.
    On earlier VCDS scans I had errors for;
    oil pressure regulator switch - replaced - error cleared.
    high voltage - alternator replaced - error cleared.
    cam and crank correlation - cam and crank sensors replaced - error does not appear any longer.
    Feb 03 2017
    Halifax/Canada
    Unfortunately - the car just cranks until you cancel it now.
    I checked the low pressure fuel line to see if the electric pump is working. I got about 200 ml from the line when the car cycled the fuel pump.
    I am not sure how best to check/test the ignition/spark system.
    Most recent scan from VCDS
    Wednesday,08,February,2023,18:00:24:57259
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
    Data version: 20221026 DS344.0
    www.Ross-Tech.com
    VIN: WAUHFCFL8CN008422 License Plate: 2023-02-08
    Mileage: 171240km-106403mi Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62 72
    77
    VIN: WAUHFCFL8CN008422 Mileage: 171240km-106403miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H20 0002
    Revision: E1H20--- CVN: FCA43ADE
    Coding: 0104010A180F0160
    Shop #: WSC 82976 802 690857
    ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
    ROD: EV_ECM20TFS0118K2907115AG.rod
    VCID: 74B1224A0E36D51BFFA-8020
    VINID: 9D195859359C2137800081020821409311
    No fault code found.
    Readiness: 1110 0100
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 BG HW: 8K0 907 379 BG
    Component: ESP8 quattro H04 0020
    Revision: -------- Serial number: --------------
    Coding: 070500
    Shop #: WSC 02391 823 56573
    VCID: 7F5BFD6637F08643928-802A
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 0B0100
    Shop #: WSC 02399 823 56573
    VCID: 76B5184218CAC70BC1E-8022
    Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
    Component: FBSAUDIB8 IDG H60 0072
    Serial number: 0811000121637018
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Serial number: 2311000171924007
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component: KLIMA 3 ZONEN H08 0180
    Revision: C1000000 Serial number: 01120820110327
    Coding: 64002000
    VCID: 00597E9A4A0EF9BBEB2-8054
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 171240 km
    Time Indication: 0
    Date: 2010.01.28
    Time: 01:39:58
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000001005954
    Coding: 26001096463CAF010000080300003D0D0F1C13080201014100 0000
    VCID: 3C21CA6A66665D5BF7A-8068
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 020811 H07 0070
    Serial number: SWF11080020552
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 11606147
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000001507113535
    1 Fault Found:
    00576 - Terminal 15
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 171240 km
    Time Indication: 0
    Date: 2010.02.23
    Time: 02:00:00
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
    Component: AirbagVW-AU10 H44 0610
    Serial number: 003GLD0NWM23
    Coding: 30453735423030303030554A304C384B3053
    Shop #: WSC 02135 785 00200
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
    VCID: 45D7AF8E152C1C93984-8010
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME63130A433
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 6344MSME617074212
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 6352QSME4B5B465CZ
    Passenger side rear thorax airbag crash sensor:
    Serial number: 6362QSME4B5B1576S
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME145B137E2
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME5F5A4E76N
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H17 0014
    Revision: -------- Serial number: 90372KH40019Q
    Coding: 000016
    VCID: 3D27C76E7D7C5453C04-8068
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 900 M HW: 8K0 920 900 M
    Component: KOMBIINSTR. H20 0258
    Revision: 00300000 Serial number: EII34T38C
    Coding: 8B0D090002000008020000
    VCID: 3431E24A4E36951B3FA-8060
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 127
    Mileage: 171125 km
    Time Indication: 0
    Date: 2022.12.15
    Time: 16:05:49
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0117
    Revision: GB800053 Serial number: 5300G1180282BB
    Coding: 00C303
    VCID: 015F7B9E4104F0B3E4C-8054
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H07 0170
    Serial number: 1102FF42090811
    1 Fault Found:
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 171240 km
    Time Indication: 0
    Date: 2010.02.18
    Time: 06:41:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.00 V
    Count: 17
    Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
    Part No SW: 8T0 035 785 A HW: 8T0 035 785
    Component: SG ext.Player H08 0290
    Revision: 00000000
    Coding: 020302
    VCID: 392FD37E69546873ECC-806C
    Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0074
    Revision: AA000000 Serial number: 00000011527403
    Coding: 00581300000000000000
    VCID: 3B23C97663685A63FE0-806E
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
    Component: TSG FA H08 1501
    Coding: 011C03204E00410001
    VCID: 53F381D6EBF8B223060-8006
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0156174270
    Coding: 0106063A00FA044483B0013200000000
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 2 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
    Component: J245 PS045 H07 0041
    Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
    Part No SW: 8T0 035 223 AH HW: 8T0 035 223
    Component: DSP STD H07 0230
    Revision: S2200000
    Coding: 0203010102
    VCID: 74B1224A0EB6D51BFFA-8020
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1501
    VCID: 52FD84D2D4E2BB2B0D6-8006
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 00000000994564
    Shop #: WSC 00000 000 00000
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 B
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    Shop #: WSC 02145 785 00200
    VCID: 392FD37E65546873ECC-806C
    Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
    Component: Con3 Sirius H06 0351
    Revision: 00000011 Serial number: AUZ5Z6K1630208
    Coding: 240200020101870003D9070800
    VCID: 46D5A88228AA178B91E-8012
    Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
    Component: Display
    1 Fault Found:
    02633 - Antenna for Satellite Tuner
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 171240 km
    Time Indication: 0
    Date: 2010.01.28
    Time: 01:40:08
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
    Component: TSG HL H06 1501
    Coding: 010C03204000210001
    VCID: 56F578C2F80AA70BE1E-8002
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
    Component: TSG HR H06 1501
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
    Component: FSE_256x BT H45 0660
    Revision: 00000000 Serial number: 00000005238639
    Coding: 0010370
    Shop #: WSC 02335 785 00200
    VCID: 3E25C0627C7A4F4BD9E-806A
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)-----------
    Jan 18 2022
    2015 A4 Prem. Plus, 1987 Scirocco 16V
    Raleigh, NC
    Im no expert but the codes in addresses 17 & 19 are concerning. Have you double-checked your connections at the battery? How old is the battery? I see you replaced the alternator, did you get an OEM part or an autoparts store one?
    Smac and others are better versed with this kind of issue but the can gateway error and ECM code are concerning.
    Feb 03 2017
    Halifax/Canada
    Alternator was a rebuild from Remy. The battery is probably 4-5 years old.
    Jan 18 2022
    Raleigh, NC
    I would get into the trunk and confirm that your battery connections are good and not corroded. I would also check the ECU box located under the cowl on the driver's side. Is there any water or corrosion in the ECU box?
    Finally, I would double-check all of your work, ensure everything is plugged in correctly, and that your harness grounds are good.
    Hope this helps and good luck!
    Senior Member Three Rings MongoMcG's Avatar
    Apr 15 2022
    B8 A4, C2 Corvette, Austin-Healey 3000 BJ8, SN95 Mustang, 36 Ford hot rod truck, A4 B9 S-line, A3 8V
    Michigan
    Just a guess for now, but it looks like a wire harness is disconnected, or that a rodent has chewed through a wire harness somewhere. The rodent thing happens surprisingly often on these cars - there is even a TSB published. The little gnaw machines hit my car twice in 12 years. The first time was up front near the a/c compressor, the second time was in the back which triggered TPMS, wheel speed sensor, ABS and a couple of other codes. Finding if such a thing has occurred only takes a careful visual inspection, but a multi-meter/continuity tester could come in handy.
    “The Force is strong with this one.”
    My K04X build thread
    Feb 15 2016
    Cambridge,Ontario
    cam crank correlation errors and won't start
    have you checked the timing chain tensioner ? that should have been first thing checked,
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
