Results 1 to 18 of 18
Thread: Revving in Park
    Veteran Member Three Rings DreamTFK's Avatar
    Nov 01 2019
    Florida
    Revving in Park
    I feel silly asking this but when I am at a stoplight and want to make some exhaust noise in Dynamic how do I do this without the car moving?
    I put it into park and change to Dynamic but I can feel the rear of the car trying to take off when I press the pedal so it goes out of park mode. Even turning off traction control doesn't help.
    In a manual it was easy but if I use neutral it kills the exhaust sound. Is it just not possible to hit high RPMs in dynamic without moving?
    2020 S4 P+ Quantum Gray BO
    ▪Wagner Competition FMIC w/Charge Pipes
    ▪ECS Carbon ECU Cover | ECS Diverter Valve
    ▪034 Trans Mount | Rear Sway Bar | Springs | 10/12mm Spacers
    ▪034 ECU/TCU Stage 2 93
    ▪Carbnlab Inlet + Airbox Mod/K&N 4" Filter
    ▪CTS Turbo Test Pipe
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    Get a tune. 034 for example, in dynamic/neutral will be loud as hell and pop violently. All your ricer needs will be solved!
    (were all ricers at heart)
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Nov 01 2019
    Florida
    I grabbed the 034 during the BF sale I just haven't done the flash yet. Doing a lot of driving for a work project and still have some warranty left.
    May 03 2014
    S4, R32
    US
    Quote Originally Posted by DreamTFK View Post
    why?
    Nov 01 2019
    Florida
    Quote Originally Posted by RatBustard View Post
    why?
    So I don't slam into the rear end of the car in front of me which is described in the rest of my post that you didn't quote.
    Senior Member Four Rings
    Nov 20 2021
    United Kingdom
    My car has never once moved a smidge when revving it in park, even at 7500rpm. It’s effectively in neutral.
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    I put it into park and change to Dynamic but I can feel the rear of the car trying to take off when I press the gas pedal down. Even turning off traction control doesn't help.
    If the car is trying to take off in park then you're not in park. Read your owner's manual before you cause an accident.
    Nov 01 2019
    Florida
    Quote Originally Posted by jtdbsr View Post
    He was asking why do you want to make "some exhaust noise" at a light? Are you this desperate for attention? If yes, walk up to a cop and punch them in the face. You'll be showered with all the attention you crave
    I know his question was rhetorical, I'm not stupid. What I want to do at a stoplight really is none of your concern now is it?
    Punching a cop has nothing to do with revving my engine you sound nonsensical and idiotic.
    Now move the feck on bro
    Nov 01 2019
    Florida
    Quote Originally Posted by Jetta03 View Post
    It doesn't but I put it into dynamic so the sound is there otherwise it's in comfort in park.
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    What about throwing it into neutral instead of park?
    '18 S4 Prestige; all packages
    Nov 01 2019
    Florida
    Quote Originally Posted by SHCKR View Post
    The sounds gets killed like it's in comfort mode otherwise that would be the obvious way to go.
    Senior Member Two Rings brandonbanana's Avatar
    Jul 14 2018
    2010 Lexus IS 250, 2023 Audi Q8, 2016 Audi S7
    Oahu, Hawaii
    I had the IE Stage 2 tune. It takes the rev limiter off. A lot of people love to tailgate me so when I get to the stop light and if they're on my rear, when I rev to 6k once and let the RPM's drop, my car occasionally spits a fat flame along with a loud POP. It makes me smile!
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by brandonbanana View Post
    Mine also tends to spit black shit out of the exhaust (have to pressure wash out of the garage every now and then), good times
    Jul 14 2018
    Oahu, Hawaii
    Apr 11 2012
    If your car moves in “park”, you are not in park. Did you just pull the parking brake and not put the transmission in ‘P’ or something?
    Feb 13 2004
    Silicon Valley, CA
    Thread cleaned. Keep it on the topic and keep the personal insults out.
    Kevin - Moderator, Audizine
    Nov 01 2019
    Florida
    Quote Originally Posted by will13k7 View Post
    I misspoke. When I was putting it into Dynamic it was just taking it out of park. I should have described what I was doing more clearly.
    Nov 01 2019
    Florida
    So I figured out the issue. I had an individual drive mode created. When I put the car into neutral it would use this.
    So the fix for me is to go into the drive mode menu, then put it into dynamic and it still stays in neutral.
    A little cumbersome but it gets the job done and I don't do it often despite some of the sarcastic opinions from others.
