Results 1 to 29 of 29
Thread: 04 USP
    Established Member Two Rings Fiction1990's Avatar
    Sep 23 2021
    Las Vegas
    04 USP
    Anybody in the Vegas area. Vegas pic a part has an 04 red sedan usp.
    09 A4 B8 3.2 lowered on raceland coilovers, 20x8.5 shift spring
    Sold 04 A4 Avant Quattro 1.8T 6m/t, Bilstein coilovers, Magnaflow catback, Hotchkiss sway bars f/r, fmic, hfc, underdrive crank pulley, 18" BBS CH., K04, MTM stg 2, 415cc injectors.
    Veteran Member Three Rings fabric8's Avatar
    May 14 2013
    US
    Sent from my SM-S908U using Tapatalk
    HIS - 2016 Golf R 6MT
    HERS - 2002 B6 A4 1.8TQM Avant | Motoza Stg.1.5 | OEM A6 4.2 17" forged fat fives
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    There’s also a red USP 04 sedan a guy is selling for $1500 with some minor issues. 128k miles but it’s a 3.0, imo 3.0 just means more standard options.
    It’s out in the middle of nowhere though, near fresno & merced area.
    https://merced.craigslist.org/cto/7568390425.html
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 05 2013
    CA
    Quote Originally Posted by Gunnarrrrr View Post
    -worst engine they ever made
    -automatic
    -red
    -sedan
    -needs to be towed "because bald tires"
    -owned by someone who didn't believe in tread
    -in merced
    doesn't get worse than that
    Mar 25 2015
    Placer County
    04 USP
    Quote Originally Posted by Spike00513 View Post
    -automatic
    -red
    -sedan
    -in merced
    I agree with every single point you just made.
    Idk there’s definitely some psychopaths on here that think red is a nice color, and wouldn’t mind a clean usp shell for $1000 to swap a new drivetrain into. could make a good 4.0tt swap project for someone. personally i’d pay $800 for it. maybe.
    the 3.0 goes straight in the trash upon delivery.
    The only good 3.0 is the cast iron sleeved b9 3.0 🫡
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jul 14 2009
    Pasadena
    easier to go 2.7 from 3.0
    IG: @matthewee
    Sep 10 2021
    Pennsylvania
    Curious... what's wrong with the 3.0 motor?
    Mar 05 2013
    CA
    Quote Originally Posted by Mike Tries View Post
    Mar 25 2015
    Placer County
    imagine the b5 2.8, but somehow just as slow, and except this time everything breaks all the time
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Sep 10 2021
    Pennsylvania
    Lol got it
    Jan 24 2010
    Paramus,NJ USA
    B9 3.0 is a bigger pile of shit than that 3.0. B9 3.0 suffers from rocker arms failure and rattles. Both piles of shit, Go VRT or 07K and call it a day although 4.0TT is not a bad option either.
    Ziddy Autowerks
    Mar 25 2015
    Placer County
    Quote Originally Posted by EuroxS4 View Post
    My warranty expired last month you take that back right now
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jan 24 2010
    Paramus,NJ USA
    When the warranty expires it means its time to get rid of it. You ever play hot potatoe? Same concept,lol.
    Ziddy Autowerks
    Mar 25 2015
    Placer County
    Too late, already did the opposite by dumping another 10k into mods and getting it ready for the tte810
    I’ll take a bad rocker arm over a bhf timing chain or any bottom end stuff like brittle rods and pistons any day. as long as the bottom end is happy i’m happy. broken stuff in the cylinder heads is just cost of doing business at this point
    Now my b6 s4 with the original timing chains, that’s a hot potato. thank god I just sold it
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Award winning Engine!
    Audi’s Older 2.0-Liter TFSI Engine Most Likely to Need Rebuild: Consumer Reports
    https://www.thedrive.com/tech/33784/...nsumer-reports
    CR’s research found that the problems develop at higher mileage, typically between 107,000 and 153,000
    The 2.0 TFSI engine was blamed for so many issues that a settlement was issued to owners unlucky enough to own an Audi with one under the hood. The successful lawsuit covered 2009-2011 Audi A4s, the 2010-2011 A5, and the 2011 Q5 for a total of 126,000 vehicles.
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by Kevin C View Post
    Don't worry there a new class action lawsuit for 2012-2017 2.0TFSI engines.... so the bullshit continues. The law suit just isn't settled yet. Long story short oil consumption continues.
    Ziddy Autowerks
    Jan 24 2010
    Paramus,NJ USA
    Rocker arms are the least of your issues. I have seen plenty of bottom ends fails on new B9 when they came out ton of metal in the oil. Initially production issues with wide tolerance range was the issue. That's what you get when you buy a car assembled in Mehico. Arriba!!!!!!!!!! However miracles do happen....
    Ziddy Autowerks
    Sep 10 2021
    Pennsylvania
    Hi, I'm Tim from dealer services. What's the year, make, and model of the vehicle?
    Sep 10 2021
    Pennsylvania
    As a newish Audi guy (whose first Audi engine rests on a stand in my garage), am I going to have to learn a phrase like "Audi doesn't make bad engines. They make good ones, and good engines require occasional rebuilds."?
    Mar 28 2015
    The 1.8T is a good engine. Some others have been a disaster. Even the worst can be serviceable if you know what your doing. In my opinion the 3.0's issues are way over blown. It's not perfect but plenty of people run them with limited problems. It got a bit of a black eye early on with cam hardening issues. At this point I'm pretty sure that any one with a soft cam is long gone. The B7 2.0T had a HPFP lobe problem. If it fails it puts a lot of hardened metal bits that make it past the oil filter. Those motors lost the cam follower way more often than the 3.0 had problems. They also had a ring sticking issue. That motor was an early GDI. GDI increase the soot load and ring clogging. The soot also works with the EP additives to prematurely wear parts like timing chains. They also have the inlet valve clogging issue.
    The B8 2.0T continued the B7's issues with a cam gear tensioner recall and more oil consumption issues.
    The issue with the B7 2.0T engine is the oil pump costs about $1800 for just the part and you cant check the bearings to know if they are scored from the cam follower. Sure you can fix one but its expensive.
    The later engines had a number of design improvements but also introduced new problems.
    What do see is many on the forums only see things in black and white, yes or no. It's completely bad or its good. If its in the good category many issue are overlooked because its good. Reality is a bit more complex, there are pro and cons and most things are a compromise. ITs up to the builder to figure out a solution. On the 1.8T its get a German cast head (not the coscast one). On the 2.0 in the B7 people check the cam follower more often.
    On my other vehicle I have what was considered at the time on of the worst engines built. The Mitsubishi 2.6 L G54B 4 with a turbo. Know of loosing oil pressure and spitting out Balance shafts, cracking heads and loosing head gaskets. A decent build and a bit of extra work and it can hold up just fine. I have 20 years on the last build and its still going strong.
    What does suck is if you bought one of the later Audi's new or used and get the expensive surprise that it needs a new motor that costs close to the value of the car. Especially if your not handy with a wrench. Payment book and a broken car.
    Mar 25 2015
    Placer County
    I’m a big proponent of AWM heads if stock, AEB if not.
    I’ve noticed the germany stamped heads are mostly found on the 03’s. But finding an AWM is even easier.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    You guys know my opinion of the 3.0. My '05 has been reliable, plenty powerful for my needs, and has a serious sound when accelerating, which is lacking in the 1.8T and 2.0T. Yes, my A5 Sportback is more powerful, gets better mpg, but doesn't have that 3.0 feel. And if nothing else, the 3.0 just looks good! Slow as a 2.8? 220HP vs. 190. Nothing has broken on mine in 275K miles (except for the plastic coolant pipe )
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by Turbo510 View Post
    I only see the problematics ones I guess. But personally from a access standpoint the 3.0 is a damn pig no access is easy to anything that normally fails on those engines. 2.8 was the best engine this is why they discontinued it because it was a low breakdown engine. Those engines got timing belts,water pumps, and wires. That was it apart from oil leaks and some vacuum lines they were bulletproof. Next best engine was definitely the 1.8T sure it had its own issues but big ticket items rarely failed.
    It depends how heavy your foot is, my 1.8T went 518k miles before I decided it was time to take it off the road.
    Ziddy Autowerks
    Sep 10 2021
    Pennsylvania
    Hah yeah. I have an AMB 1.8t. I got acquainted with that piece of junk cylinder head in a hurry, but I wanted one because my friend had a b5 Passat back in the day and we loved that car. A new head (Germany casting but the model number was machined off) made the motor happy for a while.
    Nov 03 2010
    Fallbrook, CA
    2.8 was the best engine this is why they discontinued it because it was a low breakdown engine. Those engines got timing belts, water pumps, and wires. That was it apart from oil leaks and some vacuum lines they were bulletproof.
    I had an early SOHC "12-valve" 2.8 in my'96 A4, even simpler and more reliable than the more common DOHC "30-valve". No variable cam adjustment so not great on low RPM torque, every freeway onramp was a wide-open throttle affair.
    Mar 05 2013
    CA
    To me the metal parts of the B6 1.8T look bulletproof.
    It's just all the shit attached to it that seems like such a pain. The whole birds nest/octopi worth of mazes made of rubber, plastic, pipes, hoses, tubes, vacuum, etc.
    I was at a junkyard that had a 1.8T on a shelf and wanted to know where something was located.
    The idea was it should be easier to see and take a picture where the particular component is located, with that engine being outside of the car.
    No. I could not find the part. With all that crap on top of it.
    So much more things on it than just block, head, etc.
    I often wonder if it's less of a deal to a skilled diagnoser. With less skill, it's safe to say "let's just replace EVERYTHING as a 100k mi maintenance." with various kit assortments for the above parts.
    As opposed to simply running them into the ground as long as possible, waiting for failure (hopefully just one part at a time), and then diagnosing as needed. Like smoke testing, etc.
    I wonder if it's worth trying an older Audi. 1980-1995 etc. - probably same as the above (strong metal components such as block) but with less shit attached to it.
    But being that old would be tricky. URS4, URS6, etc.
    -only old guys have the memory, knowledge, and books of working on them
    -parts harder to come by
    Mar 25 2015
    Placer County
    it’s the part availability that does it for me. every junkyard around here has at least a dozen 1.8’s. and the fact that you can get all those silly plastic and rubber parts for 1/3rd of the price from a VW dealership instead of an audi dealership. Often even cheaper than the usual ecs/fcp type stores
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Feb 10 2011
    MI
    04 3.0 USP here. 317,000 miles. ZERO trouble. Depends on what you want to do. They make great highway daily drivers. As long as you don't want to put out 400hp, you'll have a tough time finding a more reliable car. For a german car anyway. If you just don't care about your car, go buy a Toyota or a Honda.
    2004 Audi A4 Quattro 3.0 6sp Ultrasport
    2002 Audi A4 Quattro sport "development" car
    2005 Passat TDI Wagon 6 m/t
    1996 Audi A4 Quattro 2.8 (daughter)
    And all the Ford trucks you could want
    Mar 05 2013
    CA
    Quote Originally Posted by 86turbodsl View Post
    That's what I'm talking about brother HH
