Results 1 to 4 of 4
    Nov 16 2021
    Leeds
    Coolant pump issues ?
    Hope someone can help?
    If anyone can shed any light on the coolant pump issues - ive changed the pump under the cowl on the passengers side and still have same issue,
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: Malfunction 0010
    30-Special Function II -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CWUB) Labels:. 06E-907-551-CGW.clb
    Part No SW: 4G0 906 560 C HW: 4H0 906 014
    Component: 4.0l V8TFSI / X63 0002
    Revision: NCX63---
    Coding: 122A00326526010B2800
    Shop #: WSC 92521 052 00000
    ASAM Dataset: EV_ECM40TFS0114G0906560C 001003
    ROD: EV_ECM40TFS0114G0906560C.rod
    VCID: 285F4DA753F312C67B-807C
    4 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:51
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 90 °C
    Intake air temperature: 23 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 12.062 V
    Unlearning counter according OBD: 36
    Engine status: COENG_READY
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:51
    17881 - Exhaust Pressure Control Valve
    P0477 00 [047] - Signal too Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:52
    Voltage terminal 30: 12.038 V
    Unlearning counter according OBD: 40
    17882 - Exhaust Pressure Control Valve 2
    P04A1 00 [047] - Short to GND
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:52
    Readiness: 0000 0001
    Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
    Part No SW: 4G0 927 158 AN HW: 0BK 927 156 AM
    Component: 0BK 40TFSIRdW H19 1002
    Revision: --H19---
    Coding: 000001
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL551211 002022
    ROD: EV_TCMAL551211_002_AU48.rod
    VCID: 7AFB47EFFDDF50565D-802E
    1 Fault Found:
    13856 - Wheel-Speed Signal from ABS Control Module
    P1887 00 [032] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 97047 km
    Date: 2022.12.26
    Time: 17:44:24
    Unlearning counter according OBD: 35
    Voltage terminal 30: 14.290 V
    Control Module temperature: 85 °C
    Transmission fluid temperature: 84 °C
    Engine speed: 1732 /min
    Transmission input speed: 1718.00 /min
    Transmission output speed: 2577.00 /min
    Transfer speed from ESP: 114.35 km/h
    Transfer speed from ESP: valid
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
    Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
    Component: ESP9 Premium H01 0100
    Revision: -------- Serial number: --------------
    Coding: 62B7DA4146ED5B829F00
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ESP9BOSCHAU57X 004018
    ROD: EV_ESP9BOSCHAU57X.rod
    VCID: 428BFF0FD58FD89645-8016
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
    Component: BCM2 2.0 H37 0572
    Revision: 00002001
    Coding: 01B9704E000000000000
    VCID: 7BF542EBFAE5695E46-802E
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Serial number: 3215000116801002
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
    Component: KLIMA 4 ZONEN H14 0112
    Serial number: 23071500040698
    Coding: 68221078050000
    ASAM Dataset: EV_AirCondiComfoUDS 003008
    ROD: EV_AirCondiComfoUDS_003.rod
    VCID: 6ADB77AF8D7FE0D6AD-803E
    2 Faults Found:
    0560 - Supply Voltage Terminal 30 for Coolant Pump
    B11D5 15 [008] - Open or Short to Plus
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 28
    Reset counter: 49
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:51
    Voltage terminal 30: 12.17 V
    Outside air temperature: 10.5 °C
    Interior temperature: 25.19 °C
    0564 - Coolant Circulation Pump
    B10D0 31 [008] - No Signal
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 9
    Reset counter: 48
    Mileage: 97104 km
    Date: 2022.12.26
    Time: 18:49:37
    Voltage terminal 30: 14.37 V
    Outside air temperature: 9.0 °C
    Interior temperature: 23.58 °C
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
    Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
    Component: BCM1 2.0 H20 0311
    Revision: 15020001 Serial number: 00001125503601
    Coding: 0105801540349FE0690140C7A0001800CF9DC70A2F08020180 000894E100170200400024030000
    VCID: 71E960C3A8A9130EEC-8024
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS57X 150626 H37 0080
    Serial number: 150709101242
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 24106624
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
    Component: E1 - LDS H07 0044
    Serial number: 27 07 2015 00000175
    Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
    Component: EVLS-SG H08 0300
    Serial number: WA121147000014247714
    Coding: 020300
    Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: EF38CBB7000000000001
    2 Faults Found:
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 97047 km
    Time Indication: 0
    Date: 2022.12.26
    Time: 17:44:22
    03455 - Function Restriction due to Faults in Other Modules
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 97047 km
    Time Indication: 0
    Date: 2022.12.26
    Time: 17:44:25
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
    Component: Airbag10.43 H82 0086
    Revision: -------- Serial number: 003P1005WT5E
    Coding: 30333130313730323737554A305234473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 3B7582EBB265A95E06-806E
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB405D3ILE059ID
    Crash sensor for side airbag: front passenger side:
    Serial number: 3585HRB404V3H46C99NQ
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3515JRB405B3GICE7PFT
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3525JRB405P3G5J449LF
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB400453408PP0Z
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB40513IQQ8L8H9
    Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
    Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
    Component: Lenks.Modul H04 0005
    Revision: -------- Serial number: 90372NED00087
    Coding: 000035
    VCID: 377D9EDB864D8D3EE2-8062
    Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
    Component: E221 - MFL H08 0010
    Serial number: 29 06 2015 D0082622
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 45
    Mileage: 97035 km
    Time Indication: 0
    Date: 2022.12.26
    Time: 17:35:51
    Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G0 920 982 M HW: 4G0 920 982 M
    Component: TBenGb Nv H10 0104
    Revision: 06001087 Serial number: 658250715596033
    Coding: 33AF110B9B412600010400
    ASAM Dataset: EV_RBD4K 004055
    ROD: EV_RBD4K_AU57.rod
    VCID: 366393DF89477436F9-8062
    1 Fault Found:
    1048580 - Button for Trip Odometer Reset
    B11FE 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:51
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 4G8 907 468 F HW: 4G8 907 468
    Component: J533--Gateway H14 0083
    Revision: -------- Serial number: 00000001937637
    Coding: C0ED07481C
    ASAM Dataset: EV_GatewPkoUDS 001028
    ROD: EV_GatewPkoUDS_001_AU57.rod
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Serial number: 0377627203
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
    Component: J532_DCDCStab H23 0022
    Serial number: 15051300000000000102
    Address 22: AWD (J492) Labels: 4H0-907-163.clb
    Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
    Component: 4 Wheel Drive H17 0200
    Serial number: 001907150001006
    ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
    ROD: EV_AllWheelDiffeQSPFR.rod
    2 Faults Found:
    0383 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 49
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:51
    0377 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 49
    Mileage: 97035 km
    Date: 2022.12.26
    Time: 17:35:51
    Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    A guess, but I believe there are two pumps.
    The one you replaced under the cowl is V50.
    ...and on non-North American vehicles there is a V55 which looks like it would be in conjunction with the parking heater.
    However, it states there is no V50 if you have the parking heater option and therefore the V55 pump which in a different location from the V50.
    Are you sure it was a pump you replaced and not a shut-off valve?
    Otherwise it is "check the wiring" again. Sorry.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Nov 16 2021
    Leeds
    Thank you
    Do you know the location of the other pump?
    Thanks
    Sean
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by MrCUK View Post
    Thank you
    Thanks
    Sean
    It is by the parking heater.
    Unfortunately we don't get that option in the US so I don't know where it is.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
