RS6 C7 2015
Please can someone help with what I think is ABS issue,
1) During heavy rain and putting front right wheel onto the motorway white lines for a few seconds (lots of vibration) - right front ABS sensor threw a fault - which cleared - however now I have the following below - previously ive changed the hub and abs sensor on this side,
Please note - coolant pump, trip comupter button, exhaust was all present previously,
I have coducted the measuring block test for all 4 wheels
Speed test - All sensors reading fine,
Direction test - showing forwards and reverse,
position test - all ok
Please can someone point me in the right direction or any more tests I can conduct to narrow down the issue regarding ABS ?
Really apprecaite any help :)
If anyone can shed any light on the coolant pump issues - ive changed the pump under the cowl on the passengers side and still have same issue,
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CWUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 560 C HW: 4H0 906 014
Component: 4.0l V8TFSI / X63 0002
Revision: NCX63---
Coding: 122A00326526010B2800
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM40TFS0114G0906560C 001003
ROD: EV_ECM40TFS0114G0906560C.rod
VCID: 285F4DA753F312C67B-807C
4 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:51
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 90 °C
Intake air temperature: 23 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.062 V
Unlearning counter according OBD: 36
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:51
17881 - Exhaust Pressure Control Valve
P0477 00 [047] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:52
Voltage terminal 30: 12.038 V
Unlearning counter according OBD: 40
17882 - Exhaust Pressure Control Valve 2
P04A1 00 [047] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:52
Readiness: 0000 0001
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AN HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H19 1002
Revision: --H19---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 7AFB47EFFDDF50565D-802E
1 Fault Found:
13856 - Wheel-Speed Signal from ABS Control Module
P1887 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97047 km
Date: 2022.12.26
Time: 17:44:24
Unlearning counter according OBD: 35
Voltage terminal 30: 14.290 V
Control Module temperature: 85 °C
Transmission fluid temperature: 84 °C
Engine speed: 1732 /min
Transmission input speed: 1718.00 /min
Transmission output speed: 2577.00 /min
Transfer speed from ESP: 114.35 km/h
Transfer speed from ESP: valid
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
Component: ESP9 Premium H01 0100
Revision: -------- Serial number: --------------
Coding: 62B7DA4146ED5B829F00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 428BFF0FD58FD89645-8016
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Revision: 00002001
Coding: 01B9704E000000000000
VCID: 7BF542EBFAE5695E46-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3215000116801002
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Component: KLIMA 4 ZONEN H14 0112
Serial number: 23071500040698
Coding: 68221078050000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 6ADB77AF8D7FE0D6AD-803E
2 Faults Found:
0560 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 15 [008] - Open or Short to Plus
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 49
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:51
Voltage terminal 30: 12.17 V
Outside air temperature: 10.5 °C
Interior temperature: 25.19 °C
0564 - Coolant Circulation Pump
B10D0 31 [008] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 48
Mileage: 97104 km
Date: 2022.12.26
Time: 18:49:37
Voltage terminal 30: 14.37 V
Outside air temperature: 9.0 °C
Interior temperature: 23.58 °C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001125503601
Coding: 0105801540349FE0690140C7A0001800CF9DC70A2F08020180 000894E100170200400024030000
VCID: 71E960C3A8A9130EEC-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 150626 H37 0080
Serial number: 150709101242
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 24106624
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 27 07 2015 00000175
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA121147000014247714
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: EF38CBB7000000000001
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 97047 km
Time Indication: 0
Date: 2022.12.26
Time: 17:44:22
03455 - Function Restriction due to Faults in Other Modules
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 97047 km
Time Indication: 0
Date: 2022.12.26
Time: 17:44:25
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1005WT5E
Coding: 30333130313730323737554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3B7582EBB265A95E06-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405D3ILE059ID
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404V3H46C99NQ
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB405B3GICE7PFT
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405P3G5J449LF
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400453408PP0Z
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40513IQQ8L8H9
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NED00087
Coding: 000035
VCID: 377D9EDB864D8D3EE2-8062
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Component: E221 - MFL H08 0010
Serial number: 29 06 2015 D0082622
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 45
Mileage: 97035 km
Time Indication: 0
Date: 2022.12.26
Time: 17:35:51
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G0 920 982 M HW: 4G0 920 982 M
Component: TBenGb Nv H10 0104
Revision: 06001087 Serial number: 658250715596033
Coding: 33AF110B9B412600010400
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 366393DF89477436F9-8062
1 Fault Found:
1048580 - Button for Trip Odometer Reset
B11FE 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:51
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001937637
Coding: C0ED07481C
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS_001_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 0377627203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 15051300000000000102
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 001907150001006
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
ROD: EV_AllWheelDiffeQSPFR.rod
2 Faults Found:
0383 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 49
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:51
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 49
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:51
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 30071500040862
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3D718CF3AC71A76E38-8068
1 Fault Found:
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 48
Mileage: 97154 km
Date: 2022.12.27
Time: 15:46:29
Outside air temperature: 8.0 °C
Left rear vent temperature: 19.1 °C
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000081795
Coding: 01010101000000000001000102
VCID: 64C71997675BB6A697-8030
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008000
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F6DA6BB761D45FEBA-807A
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000158590175
Coding: 0078130000006001000001010101102030303232203232
VCID: 77FD5EDBC6CD4D3E22-8022
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F16015E21620002080002
VCID: 479DEE1BF6ADFDBE92-8012
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 97035 km
Time Indication: 0
Date: 2022.12.26
Time: 17:37:30
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H56 0202
Revision: 00000002 Serial number: 0000030998
Coding: 101000010001
Shop #: WSC 56833 003 1048576
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A7B87EFBD5F90561D-806E
1 Fault Found:
3164944 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 45
Mileage: 97035 km
Date: 2022.12.26
Time: 17:35:51
Write only channel
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0511
VCID: 4683E31FF1A7E4B669-8012
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 97035 km
Time Indication: 0
Date: 2022.12.26
Time: 17:37:29
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001550341
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D51BCB37C1137EE88-8078
1 Fault Found:
459776 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 97047 km
Date: 2022.12.26
Time: 17:44:21
Voltage terminal 30: 14.7 V
Internal Fault ID: 140
Vehicle speed: 192 km/h
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: Dynamic
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FE02202A130200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 3467A9D79F3B6626C7-8060
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01F00
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
1 Fault Found:
13705986 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 97047 km
Date: 2022.12.26
Time: 17:44:22
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 4G1 035 020 M HW: 4G1 035 020
Component: MU-H-ND-EU 042 1425
Serial number: A590G0F7514263
Coding: 017562010000000013111102000A00002F0008E7F1700100DF
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 23455A8B2AD5F19E2E-8076
Data medium:
Subsystem 1 - Part No SW: V03 959 801 F HW: -----------
Component: ECE 2015/2016 --- 0122
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY802AYF
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349OGM00131
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1017
1 Fault Found:
5633 - Control Head for Multimedia System; Rotary Menu Knob
B1291 F2 [008] - Unknown Error Elaboration
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 97139 km
Date: 2022.12.27
Time: 11:31:41
Voltage terminal 30: 11.7 V
