Hi guys-
Merry Christmas! I’m starting on the reassembly of my motor with rebuilt heads. I’d like to make sure I’m on the right path:
When I align the round indentation in the crankshaft with the crank lock bolt, my #3 cylinder is at TDC (passenger side rear cylinder). I have not installed the crank serpentine pulley not the plastic cover with timing marks to verify they align.
When I go to install the heads, how should I time the cams to align with motor- do I check the cam sprocket keys that engage the cam locking tool? If so, how do I make sure the cams aren’t 180 off?
I wish I had a good manual for this car!
Thanks
