Hi everyone! New member here and new VCDS user!! I recently purchased a HEX V2 cable for my A3 8P 1.6 FSI, to run some scans and check if everything is OK. I'm very new to this and trying to figure it out by reading threads here and watching youtube guides. After an auto-scan, I got fault codes for 3 addresses:
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 223
Mileage: 153374 km
Time Indication: 0
Date: 2022.12.04
Time: 18:59:00
Freeze Frame:
OFF
Voltage: 11.80 V
OFF
ON
OFF
OFF
OFF
Very rarely I get a license plate light warning on my DIS and indeed I notice the one bulb doesn't work, but 8/10 times I don't get this warning and both bulbs work fine. Note: I have only one actual light bulb and the other one is a small led integrated on my reverse camera. I don't know if it's an actual error or the system just doesn't recognize this as an actual bulb.
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
1 Fault Found:
00469 - Infotainment Databus in Single Wire Operation
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 141502 km
Time Indication: 15
I have placed an ebay infotaiment screen and not a genuine MMI, so I don't know if this has something to do. Also, very rarely when I turn the ignition on, the screen doesn't turn on, I can only hear the buttons beeping when I push them, then after a frew tries turning the screen on and off, it works.
Address 56: Radio
Cannot be reached
It says just that ! Radio works perfectly fine though. Again, I don't know if it has something to do with my ebay screen, because most of these screens have a power adapter cable, not sure if it also included a fakra connector.
If anyone knows anything about these faults, please reply!!
Thanks in advance.
