Results 1 to 1 of 1
    Dec 25 2022
    2002 Audi A4 B6 1.8T, 2005 Audi A4 B7 Avant 2.5 Diesel
    Slovakia
    Question Cam timing chain tensioner working or not? Advice?
    Hi Guys,
    Can someone confirm if this is correct?
    Looking at VCDS measuring bank #91 I can see that cam adjst. intake status shows "OFF" and Cam adjust intake B1 (act) shows "0.0°KW" this is after engine is hot and at idle. When I accelerate revs go up with engine load but the KW does not change at all. It stays at 0.00. With the cam adjst. intake status shows "OFF" and the KW not changing at all does this confirm that the tentioner is stuck or not working at all? Am I safe to say that?
    When I go to do the Basic settings for the cam adjst. intake status it does not work and keeps showing "OFF"
    Advice?
    Main issue is the P0341 Cam sensor code Implausible Signal - MIL ON
    Car is 2002 Audi A4 B6 1.8T 110kW
    Thanks heaps to everyone
