New from JDY Performance!
Our Version 2 DAZA Full-Frame Turbo Kit is capable of making big power on your RS3 or TTRS. Our kit utilizes only the best quality components to ensure your engine makes reliable power all day every day. Select from one of three different Precision Gen2 CEA Turbochargers to determine your power level. (6870, 7270, or 7275) Control boost with a TiAL MVR 44mm External Waste-gate including all springs so you can tailor it to your setup! Available in 3 colors (Red, Silver and Purple) Our Turbo kit includes everything you need to get your car up and running with no additional hardware or fabrication required! This kit fits both Left Hand-Drive and Right-Hand Drive vehicles.
KIT INCLUDES
JDY V-Band Heat Shielded Turbo Manifold.
Built in House.
EGT Ports are added per cylinder for data acquisition and the best tune.
44mm External Waste-gate Provision.
Inconel Heat Shielding.
JDY V-Band Recirculated Downpipe
3.5" Diameter
Wastegate Dump Recirculated
Flex Bellow for stress relief
JDY Mid pipe
3.5" Diameter
Mates up to OEM Midpipes
JDY Installation Hardware
JDY Turbo Inlet Pipe
JDY Turbo Discharge pipe
Includes Turbo Oil Fittings
Oil Feed and Return Line
Coolant Delete / Crossover pipe to loop the OE Water Lines
V-Band Clamps
Intake Clamps
Turbo Manifold Studs + Nuts
TiAL MVR 44mm Waste-gate
Available in Red, Silver, and Purple
Includes All Springs for the perfect boost control
Precision Gen 2 CEA Turbocharger
Exclusive GEN2 CEA® (Competition Engineered Aerodynamics) compressor wheel machined from a 2618 aluminum forging
Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
Higher efficiency and faster transient response for maximum power and performance
PICK ANY OF THE FOLLOWING DEPENDING ON YOUR POWER GOALS
PTE 6870 Gen 2 CEA
Rated for 1000HP
Ported S Compressor Cover. 4" Inlet, 2.5" Discharge
0.81 A/R V-Band 310 Stainless Steel Turbine Housing
Welded Elbow for Plug 'n Play Use with our JDY KIT
PTE 7270 Gen 2 CEA
Rated for 1100hp
Ported H Compressor Cover. 4" Inlet, 3.0" Discharge
PTE 7275 Gen 2 CEA
Rated for 1200hp
0.84 A/R V-Band 310 Stainless Steel Turbine Housing
