Results 1 to 22 of 22
    Aug 25 2022
    MA
    Adaptive cruise control wiring
    Tracing an issue i have with the front acc radars.. i get no communication whn scanned with vcds. Lookes at the wiring on the sensors and right side had broken wire, fixed but issue still present. May have to replace the connectora.
    Anyone have a diagram of how to wire them.?? Found a diagram but doesnt show which pins each wires connects to.
    Thanka
    Attachment 291569Attachment 291570Attachment 291571Attachment 291572Screenshot_20221226_090122_Acrobat%20for%20Samsung.jpg
    Sent from my SM-S908U1 using Audizine Forum mobile app
    Established Member Two Rings vrod's Avatar
    Oct 02 2018
    Germany
    Could you provide a vcds scan or similar of the modules? Otherwise it’s hard to suggest anything.
    Aug 25 2022
    MA
    Quote Originally Posted by vrod View Post
    I get no communication. I have a full scan in my other ACC post. But here is the scan just for modules 13 and 19.
    Screenshot_20221227_071423.jpgScreenshot_20221227_071546.jpgScreenshot_20221227_071633.jpg
    Feb 25 2010
    magimmeMVE
    Usa
    Scan is showing its lost comms with the right acc sensor. main loom comes from left and then branches off from left side to the right. Pin nos are shown in your 1st diagram. Check for corrosion on the pins in the plug and acc sensor
    Oct 02 2018
    Germany
    Take a voltmeter and try to check if there’s any significant resistance in the wire.. did you check the fuse (although morski says it branches out from the other radar)? I went crazy fixing my exhaust valve issues.. turned out in the end that it was a fuse problem.
    Aug 25 2022
    MA
    I did check the fuses.. manual shows fuse 7 and 11 on driver side holder A, but the wiring diagram above shows fuse 7 and 11 in Holder B..??
    Oct 02 2018
    Germany
    In my case with the exhaust valves I could not trust the manual, I has to resort to elsawin, to find the correct fuse. Elsawin would be the most correct information.
    Aug 25 2022
    MA
    Unfortunately i dont have that program
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by MikeB12D View Post
    Online subscription with print rights is $30
    https://erwin.audiusa.com/erwin/showHome.do
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Aug 25 2022
    MA
    Made huge progress.. i bipassed the pigtail connectors and both sensors are back online.. clear all fault codes.. all seem to be good.
    Removed one of the connector adaptor and pin 8 is missing on one of them.. not sure if i can find that piece as it part of the sensor but removal. Seee imagesAttachment 291673Attachment 291674Attachment 291675Attachment 291676Attachment 291677Attachment 29167820221227_120310.jpg20221227_120334.jpg20221227_120242.jpg
    Oct 02 2018
    Germany
    Sounds good, don’t forget to have the sensors recalibrated after removing them, it could be that they no longer work properly. After all, they sre also used for the front assist.
    Aug 25 2022
    MA
    Yes. First need to source this part
    Aug 25 2022
    MA
    I think its all fixed now.. took a drill put a small hole on the X where pin 8 was, thn tool a wire, fished it through from bottom and attached it directcly to pin 8 on the other side. Got 2 new pigtail connect plugs and rewired them.
    No more code and i dont think it need calibration. All working.. i figured if you dont move the adjustement screws on the sensor and it seat on the same spot on the bumper, thn all should be good.
    Thanks all for the inputs. Appreciate the help.
    Attachment 29179320221227_120406.jpg20221228_141542.jpg20221228_141600.jpg20221228_141833.jpg
    Aug 25 2022
    MA
    Possible to correct Acc alignment manually without going to dealer?
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Yes... calibration... very important!!
    When improperly adjusted (by the dealer) they will occasionally mistake an oncoming car in a turn for a stopped car and hit the brakes hard!!! REALLY HARD!!! The ACC, fighting the Assist, fighting the ABS... it was a unique experience! The tech that re-calibrated it said they were a bit off!
    I unmounted mine one time and the car had some ACC faults for a week or so regarding where it simply refused to start or stopped mid drive, then it seemed to correct itself. Maybe it has a auto-calibrate of sorts... maybe something just settled down or reseated.
    I lean towards a proper calibration now... luckily I got a freebie when they did the recall!
    Either way, be really cautious when using it for a while. It nearly turned me end for end. Took a lot of miles to trust it again!
    Cheers,
    KLS
    Jul 26 2018
    Humidity, NC
    Hmmmmm.... If you have a car with a known good setup... a 3D printer and a little CAD... you could make a jig and align any car then! I saw the video on the process... it isn't that hard!
    Would there be interest in a DIY alignment kit for ACC?
    Cheers,
    KS
    OK... maybe all you need is OBD11?? https://youtu.be/SlmP7EBCtyI
    Aug 25 2022
    MA
    Quote Originally Posted by Botbasher View Post
    Cheers,
    KS
    Thanks. Did see that video before, and would work for a small adjustment. Both of mine are way off and would require alot of adjustment, reset, drive, check, adjust, reset, drive, check...repeat until they are both in correct misaligmnt tolerence range.
    Aug 25 2022
    MA
    Anyone knows what the misaligment tolerences are?
    Jul 26 2018
    Humidity, NC
    So in that case, a jig would help to get you within striking distance of tolerance and then do the drive/check cycle till satisfied.
    Hmmmmm
    Cheers,
    KS
    Jul 26 2018
    Humidity, NC
    The video makes it seem like 1% is somewhere near the limit as he has one at 0.8 and then 0.74 and says both are below the limit but he wanted better!
    Service manual doesn't make mention of it. I wonder if ELSA does?
    Cheers,
    KS
    Aug 25 2022
    MA
    Cheers,
    KS
    Yes, it seems to throw a missaligment code when it goes over 1% and when its under 0.
    Alot driving is require as those values keep on changing the more you drive.
    I spent a day driving and adjusting to understand which away you turn the adjustement screw to make it go positive or negative number.. i then set them way off out of range ..then will start to lower then numbers, drive, and check..repeat times X times. Hope i get it right.
    Senior Member Three Rings dc2002's Avatar
    Jan 29 2007
    Roswell GA
    Check THISthread out...seems like with VCDS and some trial and error "calibration" is possible.
    2012 A6 3.0T Prestige
    EPL Stage 2
