Results 1 to 11 of 11
    Established Member Two Rings Gregory_Tolson's Avatar
    Nov 29 2022
    Wrentham, MA
    White stuff in Cabin Vents
    Anyone that has a B9 A5 having this same issue as mine? I purchased the car used and noticed all this white stuff in the vents. I tried scrubbing it with interior cleaner and scraping it with a plastic tool but it’s not getting rid of it. Not sure if this is an Audi problem or if the previous owner caused this?
    Nov 29 2022
    Wrentham, MA
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    Check near the hvac blower for a bag of coke. /s
    Do you feel funny after driving a few miles?
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Nov 29 2022
    Wrentham, MA
    Quote Originally Posted by JRYtheS4 View Post
    Very funny
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    What's the texture of the material?
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by Gregory_Tolson View Post
    How does the cabin air filter look?
    '18 S4 Prestige; all packages
    Nov 29 2022
    Wrentham, MA
    Quote Originally Posted by a4audi4fun View Post
    seems sticky and is also bumpy
    Dec 17 2017
    Long Island, NY
    Looks like someone used a deodorizer bomb in the car and had the HVAC on..
    Nov 29 2022
    Wrentham, MA
    Quote Originally Posted by RickNY View Post
    Any idea what I could use to get rid of it that won’t damage the plastic?
    Sep 08 2020
    Isopropyl alcohol is safe for most plastics
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    These may or may not be relevant for the OP's problem ...
    https://www.pca.org/tech/foam-coming-through-vents
    https://www.corral.net/threads/a-c-v...y-foam.677917/
    https://teslamotorsclub.com/tmc/thre...s-this.199684/
    As SHCKR mentioned above what does the cabin air filter look like? Can you use a mirror to look up inside the slot where the cabin filter is inserted (with the filter out)? Also, if you can remove the plastic panel under the hood that covers the fresh air intake, can you see any evidence of animal activity or foreign materials of any sort? It may require removing the wiper arms to get the panel out, but you may be able to look under the front edge of the panel to see if the water drains are clogged with debris or if the fresh air intake looks clean and debris-free.
    https://workshop-manuals.com/audi/a1...intake_grille/
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
