Results 1 to 10 of 10
    Senior Member Three Rings Sukks2bu's Avatar
    Mar 12 2013
    Milton Ontario
    Burning oil smell after driving a short trip
    Hello everyone, I know there are threads with oil consumption issues, I’ve posted in there before, however I believe I may have a different issue the the regular PCV valve replacement.
    I have a 2010 s4 with 225k, unitronic stage two and no other mods. I’m consuming about a litre of oil every 1100 kilometres.
    I’ve had the PCV replaced at 160k.
    I also have black spay coming out the Exaust on startups. But recently in the last 6 months or so , I’ve noticed the smell of burning oil, even after a short trip to the store when I park my car in the garage. And it seems to be getting worse.
    There are no signs of an oil leak.
    Any advice or suggestions would be greatly appreciated.
    Senior Member Four Rings
    Jun 08 2021
    PA
    Smell of burnt oil can be out of the exhaust valve guides. I’m a motorcycle mechanic and we see this with very high mileage bikes. It will not smell like your classic burning oil through the combustion chamber. It will get pushed into the exhaust system and never really “burned”. It leads to an oil baking smell similar to a leak onto a hot surface. Run your finger inside the exhaust tips. Dry sooty is normal on direct injection but if it’s wet or pasty I’d say it’s exhaust guides.
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    With 225k miles, maybe throw some liquimoly oil saver in your next oil change and see if it helps. Might help you avoid having to do guides on an old, high miles engine.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Mar 12 2013
    Milton Ontario
    The smell is definitely coming from under the hood area.
    Sep 08 2020
    Quote Originally Posted by Sukks2bu View Post
    Ooooh. Yeah that would not be valve guides. I would guess valve cover gaskets or oil filter housing, in that order. Valve cover can drip right onto the exhaust manifold.
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    I was gonna mention valve cover gaskets.
    At 97,000miles, mine were hard as a rock and leaking badly, along with my rear timing covers each of which will let oil drop on to exhaust manifolds or cats.
    Sep 08 2020
    Quote Originally Posted by B7TitaniumA4 View Post
    Mine has both these issues right now with 130k. Oil pan too. It's seeped for a while but now it's bad enough to start dripping occasionally.
    Mar 12 2013
    Milton Ontario
    Thanks for your input gents
    Mar 12 2013
    Milton Ontario
    Also, I’m looking to maybe sell my car so I do t want to sink a ton of money into her, but I’m guessing the liquid Molly oil saver stuff won’t help this if it’s a valve gasket
    Sep 08 2020
    No, probably not. Oil saver is just a band aid. At least on this car the gaskets are pretty accessible.
