Results 1 to 3 of 3
    Dec 07 2017
    Spruce Grove Ab Canada
    Technology doesnt like cold
    Soo I'm one of the clingers holding on to an epl stage 2 tune, and my car had a sleepover at the bar the other night and it was -36°c overnight and in the morning. When i went to pick it up and start it in the morning, the dash lit up like a christmas tree, low coolant light, mmi screen wouldn't turn on, drivers side window did some funky up and down stuff when i opened the door. Let it warm up for a bit and checked the fluids, all good, drove it home and parked it and turned it off and off again, and everything is fine, except 1 thing - when you open the door by grabbing the outside handle, the window goes down like 6 inches, and when u close the door it just goes up the little bit it usually does when you open the door (s5 sportback). Is there any way to reset that door window function with the obd11, or is this a dealer problem, a potentially tune erasing dealer problem?
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    To reset the windows press and hold all the way down for about 5 seconds and then press and hold all the way up for about 5 seconds. The window should be reset at that point.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Dec 07 2017
    Awesome i will try that today, thank you very much
