Results 1 to 9 of 9
    Veteran Member Three Rings Audi Advocate's Avatar
    Mar 26 2005
    2012 B8 S4, 2012 A3 Wagon
    Has anyone with a B8 (and B&O audio) in here done audio upgrades?
    I've maxed oout on outside mods - the 2012 B&O is so old. From Forum search I am seeing that its not possible to upgrade the head end unit since its got MMI integration. Are speaker upgrades the only option to "spruce up" my interior? LOVE my S4, she's just a little old school on the amenities. I appreciate any suggestions. Forum search ahs a ton of DIY - alas I am not that smart to DIY - will be an audio shop to do any work ....
    Current #1 2012 S4 3.0T DSG Technik with Unitronic Stage 1+, Milltek res., KW V2 coilovers, StopTech BBK, Alu Kreuz, H&R Rear Sway, BBS CH-R's, Michelin PS4S, Disabled wink, De-badged, ZIZA LED's, 30% tint and fancy aluminum pedals - Current #2: Wife driven 2012 A3 2.0T Progresiv- stock
    Senior Member Two Rings Lockon_B7's Avatar
    Oct 17 2014
    New Jersey
    captain_video makes an upgrade kit for the 3 dash tweeters.
    2016 A4 auto P+ Daily driver
    2016 S3 Sepang Blue Sold
    2009 A4 2.0T, 6MT, P+, Sport Package, Meteor Grey. Sold
    2008 A4 2.0T 6MT RIP
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    Yes, DMP car design (out of Malaysia)
    I have the B&O but the “cheap” MMI.
    This upgraded me to a nice big touch screen, nav and Bluetooth/wireless carplay.
    The only thing I need to add is a microphone for hands free talking, not sure why it wasn’t included.
    Mar 26 2005
    Thank you - will check these out!
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Audi Advocate View Post
    The information you’re after will likely be in the thread below.
    https://www.audizine.com/forum/showt...upgrade-thread
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Junior Member Two Rings suths's Avatar
    Apr 27 2017
    BMW X3 - Family Wagon
    London, UK
    The B&O system sucks. The speakers are actually made by a company called Faital and are very poor quality. The rear sub is pitiful.
    The only contribution B&O made was to the amp software for the surround sound.
    I’ve changed nearly everything in my car and it sounds so much better.
    Full list:
    RSNav S3 10.25” Android Head Unit connected to the AMI via FiiO E10k USB DAC and NobSound Sound isolator
    Pioneer Dual voice coil 4 ohm 10” rear sub wired in series to replace the factory sub on the rear deck
    Audison AP8 speakers in the front doors
    Audison AP65 speakers in the rear doors
    Front dash and rear deck mids replaced with
    Dayton RS75-4 and installed using harnesses and brackets from captain_video on here. 5 in total.
    Final piece is a Musway D8 v2 DSP. I didn’t want to rip out the factory amp as I wanted to retain Bluetooth and other functionality routed through it. The Musway is oem + and connects to the oem amp via a wiring harness. No need to cut wires. It just works. You’ll need to get power from the battery but it’s so simple as the battery is right there in the boot. I’ve also had the DSP professionally tuned as my attempt was terrible.
    The only things that are still oem are the front and rear door tweeters. I couldn’t find a viable plug and play solution for those. I’m not an audio guru and the thought of having to add crossovers was a little too much for me when I did most of the work. I may revisit it once I have more time.
    With all of the above installed, the only problem I have now is rattles. I’ve used baffles and a large amount of dynamat everywhere but the plastics still rub. I’ve now resorted to cutting up pieces of foam for seats and pushing that into crevices to stop the rattles. Seems to be working well so far.
    Veteran Member Three Rings coop3422's Avatar
    Jan 11 2019
    Calgary
    I added a JL sub, amp and LCi2 to mine. I won't say I hate it, but I really don't like the way it hits/sounds. It was the same when I had it in my A6, might be a tuning issue but it gives me a headache. I'd be interested in upgrading the speakers etc in hopes to get everything sounding good, but there's a lot of costs to properly integrate it so I've left it as is.
    2015 Audi S4 Sepang Pearl Blue | 6MT | Technik | Sport Diff | B&O | Black Optics | Hertz HCPD1 & JL 12W3V2 | AWE stage II Single Pulley | AWE S-Flo Intake | 034 RSB | CR15 | JXB Ultm Kit | BFI Heavyweight | 19" Rotors w/ MPSS | 18" Peelers w/ Blizzaks
    Apr 27 2017
    London, UK
    Quote Originally Posted by coop3422 View Post
    Speakers definitely help especially the front dash and lower doors. I’d suggest investing in some new ones if you want to have a better overall sound.
    But my main advice is to get the system tuned properly. I tried to tune the new DSP myself and it was terrible. Took it to a specialist who spent 1 hour tuning and it now sounds excellent. The majority of that hour was spent setting things up with only 20 mins needed to actually tune it which was impressive. The tuner is an official Musway partner here in the UK which made it easy for him.
    2009 B8 S4 - JHM OAD 207MM pulley, Merc Racing Heat Exchanger, AWE ADS Cooler, CTS Turbo Intake, H&R Springs, H&R ARBs, Custom Front Strut Brace, Q5 Brembo Calipers and failing cats
    Mar 06 2019
    Indiana
    Does anyone know if the non-b&o front dash twitters can be upgraded with some b&o ones? Are they plug and play?
