I got a new transmission at 96k km... see here https://www.audizine.com/forum/showt...ion-installed!
And 6000km later I got a transmission failure error in the dashboard, scanned it and then drove it to the dealer.
They scanned it too, confimerd that I can no longer drive the car and then gave me a loaner (brand new 2023 A4) which I have been driving for the last 3 weeks...
In the meantime the Regional Tech had a look at it and they are waiting to hear back from Audi in Germany.
The dealership is very supportive and keeps me informed on a regular base.
Here the scan result:
Address 02: Auto Trans Labels: 0BH-927-711.clb
Control Module Part Number: 0GC 300 012 A HW: 0GC 927 711 G
Component and/or Version: GSG DQ381 H06 1628
Software Coding: 0014
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ381061 001 (AU37)
ROD: EV_TCMDQ381061.rod
VCID: 21673FF630981C85AD-8074
1 Fault Found:
35494 - Control Circuit for Aux. Trans. Fluid Pump
P0C29 00 [047] - Implausible Signal
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 0
Fault Frequency: 4
Mileage: 102823 km
Date: 2022.11.23
Time: 18:24:53
Engine RPM: 757.00 /min
Vehicle speed: 0 km/h
Coolant temperature: 92 °C
Clutch: primary stat: Creeping
selected gear: GANG_1
Driving position: d
Engine torque: 16 Nm
Control Module temperature: 24 °C
Accelerator pedal position: 14.9 %
DTC memory status: 296
Not much found on the internet...
Does anyone have knowlege or experience with this?
I will update once I hear back from the dealer...
