Hey everyone, new member here with a "new to me" 2004 1.8T A4 project I picked up from a friend who had done some troubleshooting and basically given up on it after getting himself a Mk2 TT.
Anyway, here's the VIN:
WAULC68EX4A035147
The car has been taken care of pretty well except for a little body damage on the passenger side. I'll get that lined out in the near future. For now I'm trying to diagnose a misfire on Cylinder 2. I don't have a Rosstech yet but I do have an OBDII scanner and I am getting a Cylinder 2 Misfire and P0202 Cylinder 2 Fuel Injector Circuit Open codes.
Long story short I pulled the injector harness, stripped the harness insulation back to the #4 injector and found two bad spots on the wires. One was on Cylinder 1 and Cylinder 2 did have a knick in both wires insulation. Cylinder one had the insulation missing and the wires were twisted together and touching.
So I ordered 4 Bosch EV1 connector pigtails and last night I cut out the two bad spots in Cylinder 1 and 2 injector wires and replaced them with the new connector pigtails. I closely examined the harness all the way back to Cylinder 4, right before the harness drops in behind the engine block and other parts of the harness join together. Everything looks good to that point and I'm starting to get into a really tight area.
So before I get into cutting apart the harness any further I wanted to get some opinions on whether the Cylinder 2 injector itself could be the cause of the P0202 Open Circuit code? The injector terminals look good and the connector itself is new. I guess I could swap it to another Cylinder to see if the code moves to that circuit?
I'm planning on making a new injector harness. Using a 12 pin Molex Plug that will connect back just behind Cylinder 4 injector. I thought that was better than a big wad of butt splices/crimp connectors. I also want to try to adapt a plastic wiring conduit from a later model 1.8 or 2.0 for a little added heat protection.
I'll have to see what works? I plan to do the same thing to the coil pack harness. I plan to go through everything and get it back to solid running condition. This car has had the timing chain done and everything was properly maintenanced. I plan on rebuilding the turbo or possibly upgrading it. This car has the GBF transmission, I don't know what kind of power this transmission will handle?
I'm not trying to get crazy with it, but would like to be able to get ~225hp with a tune and rebuilt/upgraded turbo. I just have to get everything else rebuilt and tuned up first. I'm new to Audi's and VWAG cars in general. So I thought I would check with those more experienced and see if I can get some opinions on what I can do to this engine to make more power but not risk junking the GBF transmission.
Maybe down the road I'll swap in a manual transmission, swap the AMB head for an AEB head and build it. For now I just want to get it reliable and enjoy driving it while upgrading along the way. I love this car, I have built BMW's and a Scion TC this way and all those cars still run to this day.
I've really fallen for the Quattro and the 1.8T engine. I've driven this car in the past and helped my friend work on it here and there. Now that it's mine I want to give it some much needed attention.
Any advice on the codes or parts that should be serviced and/or upgraded is most welcome.
