The 034Motorsport SüperDüper S34 Insuction Bundle is finally here! The SüperDüper S34 Insuction Bundle for the B8/B8.5 Audi Q5/SQ5 includes all of the best 034Motorsport products required to upgrade your intake system in one comprehensive and convenient package. Included with this kit are the SüperDüper 84mm Throttle Body System and S34 Carbon Fiber Intake.
Features:
  • Developed In-House by 034Motorsport's Engineering Team
  • Cast and Machined A356 Aluminum Throttle Body Adapter
  • Improved Flow Where the Stock Throttle Body Becomes Restrictive
  • 20% Increase in Flow Over the OE Throttle Body
  • Stock 70mm Throttle Body & Intake: 380 CFM
  • 034Motorsport 84mm SüperDüper S34 Insuction Bundle: 457 CFM
  • OEM BMW V8 Throttle Body for Reliability and Long Lasting Performance
  • Smooth Transition from the Large Throttle Body to the Supercharger Inlet
  • Throttle Body Adapter and Gasket Can be Port Matched to the Supercharger During Supercharger Porting, Allowing Even More Flow
  • Fits Both Left and Right Hand Drive Configurations
  • High-Quality Carbon Fiber Air Block-off Shield
  • High-Gloss Epoxy Finish
  • 4-Ply Gloss Black Silicone Intake Tube
  • OEM+ Fit and Finish
  • No Rubbing or Excessive Movement
  • Dyno-Proven Horsepower Torque Gains
  • Improved Airflow from Factory Airbox and Intake Tube
  • Enhanced Engine Induction Sounds
  • Improved Throttle Response
  • Large 4" Inlet Conical Pleated Cotton Air Filter
  • Reduced Intake Air Temperature
  • Securely Installs Using Factory Mounting Grommets
  • Simple, Straightforward Installation Instructions
034MOTORSPORT SÜPERDÜPER CHARGER 84MM THROTTLE BODY SYSTEM
The 034Motorsport SüperDüper Charger utilizes a VDO 84mm throttle body mated to a cast and machined aluminum throttle body adapter, offering a smooth transition between the larger throttle body to the supercharger inlet. This results in a 20% increase in flow over the OE throttle body right out of the box. Additionally, the throttle body adapter and gasket can be port matched to the supercharger during supercharger porting, allowing for increased airflow.
034Motorsport Dynamic+ Tuning is required to safely run this SüperDüper Charger 84mm Throttle Body System. Files to support this upgraded hardware are included with our Stage 2+ 91, 93, 100, 104, & E40 octane options free of charge. Simply select the file designated with SüperDüper and you’re good to go! NOTE: This is only for Stage 2+ files. We do not have Stage 1 or Stage 2 files for the SüperDüper Charger.
Check this out here!
