Results 1 to 6 of 6
Thread: Cluster
    Feb 23 2022
    Montenegro
    Cluster
    After changing my high beams to led (trying to see if bulbs work on contact for several times)my high beam indicator burned in cluster,in daytime its not a big deal but in evening becomes very annoying.What could I do to make it dissapear?
    Послато са SM-G960F помоћу Тапатока
    Feb 23 2022
    Montenegro
    If you didnt understand me,here is a pic
    My high beams are not turned on.
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Try putting the old bulbs in and see if the light goes out. If it does then the LED bulbs are the problem.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Jun 05 2019
    95.5 UrS6 avant; 16 SQ5 (wife’s); 89 Jetta ; 90 Quattro V8(sold); 07 MDX; 85 Magna
    SE Pa
    My car did the exact same thing after putting in led low beams. Since the resistance is much lower the excess current has to go somewhere I guess. My car is a 97 btw.
    Jun 30 2008
    Erie, Pennsylvania
    You could try adding a small, non-diode type of load to the high beam side. Like a resistor. Perhaps try adding them directly from the fuse box with a fuse-tap device just for ease of experimenting. I'm thinking the circuit just needs a "path to ground" when the power is off - and the LED is doing a crap job of that. I'd probably start with 1k Ohm resistor, then try a 330 Ohm (or just keep adding more 1k's in parallel until you see a change). 1 watt rating is enough to experiment with.
    Dec 30 2013
    Australia
    The same thing happened to mine although it's relatively dull on low beam and gets brighter on high beam so I can live with it.
