Results 1 to 22 of 22
    Aug 07 2022
    Eagle, Co
    Anyone have a part # and source for this?
    As title says, I’m looking to replace these ties along the firewall. Thanks
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    FWIW-
    I have used these folks when looking for odd cabling ties and such...
    The only issue is you need to purchase in quantity
    https://www.waytekwire.com/products/...ng-Cable-Ties/
    I started by emailing the company requesting samples for test work--implying I'm an engineer working on a project....
    YEAH- I know----shame on me....
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    Northern Virginia
    I broke all of those things many moons ago, they're so damn brittle.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Veteran Member Four Rings belms4's Avatar
    Apr 17 2019
    2000 silver S4, 2001 imola S4, 2002 Avant nogaro RS4 conversion
    Man I spent a ton of time just a couple days ago looking for these exact ones for my restoration. I couldn't find them in any parts diagrams and searching every variation of "cable tie" you could think of came up empty. Closest I found were reusable cable ties that go on a threaded stud like that, but not the zip tie style.
    Part #8D0971850C
    https://www.ecstuning.com/b-genuine-...ch/8d0971850c/
    Next closest was a zip tie style, but they're the ones that stick into a sheet metal hole instead of screw on a stud.
    Part #1K0971818
    https://www.ecstuning.com/b-genuine-...rap/1k0971818/
    I'll let ya know if I ever find the right part number for the exact one we're both looking for. Suspect they are NLA. LJS may have a decent replacement there too.
    Sent from my SM-F721U1 using Audizine Forum mobile app
    Junior Member Two Rings Bernd's Avatar
    Jan 29 2018
    03 AUDI RS6 C5 Station Wagon 6SpMT
    Bremen/Germany
    Hey guy's, I think I can help you :) was in the same situation, as I needed those for my RS6.
    Even though I don't know if you can order them in US, but at least you have part numbers
    cheers
    https://nemigaparts.com/de/cat_spare...el/198/979100/
    Best to keep in mind: It doesn't matter how fast you are going, someone out there is faster!
    Aug 07 2022
    Eagle, Co
    Thanks guys- wow I thought they’d be out there somewhere and that I just could search right…
    Apr 17 2019
    Quote Originally Posted by Bernd View Post
    cheers
    Thanks this is awesome!
    I think #7 is as close as I'm going to get
    Part #
    N90357101
    About 71 cents each
    Veteran Member Three Rings wpfahl's Avatar
    Jan 07 2013
    2001.5 S4 Avant. 1997 A6 Base, 1997 A6 Avant, 2014 Jetta Hybrid, Ford F250
    California
    Thanks for the part#.
    eBay for 1.20 each.
    Sent from my magic phone
    Mar 04 2014
    Northern Virginia
    ^ Great seller too, last time I ordered from them I got my part from Latvia to USA faster than some domestic shipments.
    2003 Audi S6 Avant
    Apr 17 2019
    Got some bad news on part N90357101. I got a bag of them last week and finally took one out to check fitment. The cap style end that should screw onto a threaded stud is much bigger than most of the threaded studs that require these on a B5. A pic below shows one of the original cable ties "cap" type end that fits (slightly different style of tie) next to N90357101. It's too big to thread on. So the search continues for this exact zip tie style that fits a B5. At least they were cheap to give a try.
    I also got some of part 1K0971818. These are the green ones pictured and clip into a body hole with the zip tie style of tie. They do fit.
    I'll be ordering 8D0971850C next. These are marked for a B5 and should fit the threaded studs. The tie style is not a zip tie though, they're more a reusable ladder rung looking type of tie (the one I'm comparing to in my pic).
    Aug 07 2022
    Eagle, Co
    hey Belms-
    I got my order of the ties also and they're too big to fit the posts like you said. How did you make out with the new order? Actually I would like to get some of the ladder style and some of the zip tie style. Which did you end up with?
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    8D0971850C appears to be what you want. Number 11 from the link above.
    Apr 17 2019
    Quote Originally Posted by Hmh800 View Post
    hey Belms-
    Yeah they fit some of the posts, but very few around the engine bay are that size (if any). The green ones I pictured work great, but they fit into holes and won't help with any posts. I've tried a bunch now and still haven't found any from Audi that fit these posts. Closest I've found are some zip ties on Amazon that have 1 end meant for putting screws through to mount to something.
    Black Zip Ties with Screw Holes-... https://www.amazon.com/dp/B08HR9BTRJ
    If I drill the hole a tiny bit larger they fit the threaded posts. Best I've found yet. Would love to find a replacement from Audi that are either style (zip or ladder) and fit the threaded B5 posts but I've kinda given up looking for now.
    Apr 17 2019
    Quote Originally Posted by mauromj View Post
    I tried those too. The post end was too big unfortunately and would just slip over the studs without threads biting at all.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    You could 3D print small inserts to lessen the ID on those.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Apr 17 2019
    True. I don't have a 3d printer or access to one though. Tried the cheap and dirty version of that wrapping a couple layers of tape around a post and even then the cap part of the wire tie was too big. For my purposes I'm good with the ties from Amazon since I'm retying all the wiring under the carpets where the ties broke removing them and nobody is going to see those.
    Apr 17 2019
    Late update on this but I finally found suitable factory replacements for these cable ties that are in the style of the originals. Since Audi sucks at maintaining parts for any of their classics I actually found the right size ties from BMW. Had a friend with a 335 measure the threaded post size for these ties on his car. Same 5mm size the B5s use!
    So ordered 10 of each of these through FCP and they fit perfectly!
    Cap "ladder" style ties that go on threaded posts:
    BMW part 61131389024
    Ladder style ties that snap into body holes:
    BMW part 61131391721
    Aug 07 2022
    Eagle, Co
    Huh, nice. It’s interesting how these small parts (thinking fuel line clips on airbox) are interchangeable between brands.
    Apr 17 2019
    Yeah more or less same design. Apparently Audi upsized all the post ties to fit 1/4" posts and killed whatever original part fit the B5s. I haven't searched too hard but I'd bet BMW sells the zip tie style that attaches to posts too.
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Any chance you looked at either of these?
    N90643701
    N90476101
    I think the second one is same as the BMW part 61131391721 just sold under a diff P/N (and for more money of course lol)
    Apr 17 2019
    Quote Originally Posted by PwrWgn View Post
    N90643701
    N90476101
    That second one should fit for sure. Any of the snap in types like that I've found are pretty forgiving and fit well.
    I haven't tried that first one though myself. At least not that I can remember recently. Definitely interested to hear if it fits. Next order from Audi I'll have one thrown in to check fitment. Thanks!
    Edit: Interesting, I just noticed I had N-906-437-01 already saved in one of my wish lists on the ECS site. Not finding if I ever bought it and tried it though. Apparently I've tried too many to remember now haha.
    Veteran Member Three Rings ss4's Avatar
    Jun 04 2005
    San Diego
    Quote Originally Posted by belms4 View Post
    Appreciate the information sir. Small things to keep this platform going.
