Results 1 to 3 of 3
    Nov 03 2017
    craigsville
    Windshield wipers
    I’m having an issue with my wipers. They was slow and acting erratic. Completely stopped one day. Read that the transmission could be seizing….So I bought a new linkage system. And a new motor. Put it all in and worked for a couple days and same thing.
    Nov 03 2017
    craigsville
    So I did some more research. Fairly certain it’s the Cecm. I pulled it and some of the pins look pretty rough and had some moisture in it. But next question is I got the code off of it and put it into eBay. A lot of them look the same but have a different last letter. Would they still work?
    Dec 08 2018
    South Yorkshire, UK
    It would help if we knew the year and model. Also what was the code on your CECM. Can you read any codes from that moduel?
    Larry
    2002 A4 B6 1.8T
    Tuned Stage 1, BSR exaust, RS4 rear sway bar, A4 B7 320mm Brembo disks, calipers, SS brake Lines, B7 wiper arms and blades, Valeo HD SMFW Clutch.
