I'll try to keep this brief, but it involves a narrowly avoided catastrophe.
About two weeks ago I put on my winter tires. Unfortunately the tire shop torqued the bolts to about 3000 ft/lbs. Also unfortunately I rounded 3 of the the stock lugs in getting them off. I like lugs with nice sharp edges, so I decided to get new lugs from FCP Euro (1st order from them). FCP Euro indicated the lugs were compatible. I noticed they were a different design in that the "shoulder" (my term) was separate from the lug bolts, unlike the single piece lug bolts that were stock. I figured they were an updated design and used them.
Anyway, I hadn't driven the car since I put the snow tires on until last Thursday. I stopped after about an hour with my car shuddering like crazy on the Capitol beltway (if you know, you know) in the wind, rain, and high speed traffic, missing a rim center cap and bolt (somewhere along I-66E), two lug bolts just dropped next to my wheel when I stopped, and the remaining two lugs so loose I could turn them with my hand. I cranked the bolts that dropped on the ground, and the two loose bolts that remained on the rim, probable 2 miles from my wheel coming completely off. After that the car drove smooth as silk.
I called the local Audi dealer (Silver Spring Audi) to ask if they had any lug bolts. They asked "do you want the one-piece or two-piece?" Well, I didn't realize there was a difference so I went with the "one piece" because it appears the "two piece" bolts backed themselves out of the hub. Mind you I didn't hand tighten the bolts, I used my impact driver for that. Perhaps I should have double checked to see if they were tight.
So, my question is, is there a significant difference between the two bolts designs (aside from the obvious "one piece/two piece", or am I the lug here? Should I contact FCP Euro to let them know of the issue?
