Results 1 to 4 of 4
    Junior Member Two Rings DVS S6's Avatar
    Jan 06 2020
    Birmingham, AL
    Lowering module suddenly stops working
    Hey guys, does anyone have any experience with the CETE or AK Racing lowering module just stop working randomly?
    It's the wifi model and was working fine for over a year but today when leaving work I get the "warning for air suspension system fault, you can continue driving slowly, max 35mph".
    It does not allow me to raise or change the drive select and I cannot find the wifi connection anymore to adjust the lowering module.
    Does anyone have any suggestions?
    Thanks
    Sent from my SM-N986U using Tapatalk
    Mar 29 2014
    Hampshire, UK
    You should have the by-pass plug which allows you to take the Cete module out of the circuit, and allow normal operation. That at least restores normal service.
    The only time I’ve had an issue with mine was when it was disconnected by the garage when they were doing the oil filter recall (the garage has to run a before and after scan for codes as part of the recall). They didn’t hook it back up
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Aug 14 2012
    S4 B5 Imola Yellow, A6 4G Mugello Blue
    FIN
    Had a fault once with AK Racing (electronicworks.de) module, where the car just got stuck to high setting and gave some faults. Unplugging the module helped and after updating the firmware this hasn’t happened again.
    Jan 06 2020
    Birmingham, AL
    Thanks guys for the advice, got info from AkRacing to update and hopefully that fixes it.
