To all my Audi Gurus/Specialists,
I could really use your help!
I decided to purchase a used 2018 audi s7 w/30k miles from out of state. I had it inspected prior to purchasing and the below info was on the summary:
- aftermarket exhaust
- removed cats and replaced with straight pipe
- rich and lean faults stored.
I do not know a lot about vehicles and such modifications. But based off the technicians inspection report and discussing with him, he made it seem like the vehicle was good to go.
So I purchased the vehicle and had it delivered. Not even a 100miles worth of driving, I noticed that it was driving a little rough (shakes/vibrates) and out of nowhere, white smoke coming out the tailpipes causing the check engine light to turn on. I brought it to the audi service in my area to have them look into my issues. Below is what they diagnosed..
- rich and lean faults stored in system
- check engine light on, white smoke coming out of exhaust (smells like burning oil).
- both turbos have been replaced. Possible cause for oil being in the exhaust may be due to bad turbos and oil was blowing by.
- ecm is tuned
- car feels like it has a misfire but no codes or faults being read. Possible ecm and aftermarket may be the reason for this running condition.
- found throttle body gasket to have a cut in gasket, which could cause the engine to run rough. Replaced gasket, still runs rough, but better than before.
Based off this info (hopefully it was detailed enough) what are my next steps to getting this vehicle to drive right with no issues? I am out of luck on giving back to the dealer and at this time, can only hope that the audi service that initially inspected the vehicle or the selling dealership will compromise on making things right and meeting me halfway to resolve the issues.
Suggestions/recommendations??
Thanks all!
