I am struggling with an issue that just came up on my B8 A4 Avant. I've done a fair bit of work to this car recently and have driven it about 800 miles since with no issues. Yesterday I was driving locally and the car lost power, misfired a couple of times and died at about 20mph. I pulled over and turned the car off, attempted to restart, and the car wouldn't fire up. It's cranking and there are no lights on the dash. I have posted a scan below and was hoping someone on the forum has experienced something similar with their 2.0t.
A few other clews that I noted while on the side of the road. - It smelled like gas around the engine bay after the incident -- After opening the oil cap out of curiosity it really smelled of gasoline ----
I sincerely appreciate your help in advance.
Code:
Tuesday,20,December,2022,17:41:27:51688 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: WAUWFAFL4AA036069 License Plate: Mileage: 255650km-158853mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FL-AU48 (8T0) Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72 77 VIN: WAUWFAFL4AA036069 Mileage: 255650km-158853miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D Component: 2.0l R4/4V TF H15 0001 Revision: E1H15--- CVN: CC36E0B0 Coding: 010C010A190F0160 Shop #: WSC 01126 444 104924 ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 ROD: EV_ECM20TFS0118K2907115AL.rod VCID: 79AFEB4C8955CC43ACC-802C VINID: 9D196759159C1114400C600624D392D4CC 5 Faults Found: 5456 - Starter Will Not Turn P3054 00 [096] - Jammed or Electrical Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 254621 km Date: 2022.11.29 Time: 15:52:02 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 77 °C Intake air temperature: 60 °C Ambient air pressure: 1020 mbar Voltage terminal 30: 12.156 V Unlearning counter according OBD: 18 5463 - Starter Control; Returned Message P3052 00 [032] - 50 Short to Plus Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 254621 km Date: 2022.11.29 Time: 15:53:59 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 76 °C Intake air temperature: 60 °C Ambient air pressure: 1020 mbar Voltage terminal 30: 12.015 V Unlearning counter according OBD: 18 4054 - Cylinder 1 P0301 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 255654 km Date: 2022.12.19 Time: 20:07:34 Engine RPM: 985.50 /min Normed load value: 9.8 % Vehicle speed: 0 km/h Coolant temperature: 98 °C Intake air temperature: 14 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 12.510 V Unlearning counter according OBD: 80 4063 - Cylinder 4 P0304 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 255654 km Date: 2022.12.19 Time: 20:07:34 Engine RPM: 985.50 /min Normed load value: 9.8 % Vehicle speed: 0 km/h Coolant temperature: 98 °C Intake air temperature: 14 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 12.510 V Unlearning counter according OBD: 80 4051 - Random/Multiple Cylinder Misfire Detected P0300 00 [101] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 255654 km Date: 2022.12.19 Time: 20:07:34 Engine RPM: 985.50 /min Normed load value: 9.8 % Vehicle speed: 0 km/h Coolant temperature: 98 °C Intake air temperature: 14 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 12.510 V Unlearning counter according OBD: 80 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb Part No SW: 8K0 927 158 J HW: 0B6 927 156 Component: 0B6 20TFSIUSA H05 0008 Revision: --H05--- CVN: 1C1436D7 Coding: 001012 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_TCMAL651 A01006 ROD: EV_TCMAL651.rod VCID: 3D273F5CDDFD3063C04-8068 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 CA HW: 8K0 907 379 AN Component: ESP8 quattro H04 0010 Revision: -------- Serial number: -------------- Coding: 150D18 Shop #: WSC 06335 000 00000 VCID: 7AADF4408CD3C75BA56-802E No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG Component: BCM2 1.1 H02 0321 Revision: 00002001 Coding: 090200 Shop #: WSC 06335 000 00000 VCID: 78A9EE48B2DFD54BD32-802C Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A Component: FBSAUDIB8 IDG H37 0060 Serial number: 0509000035663011 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0209000047416004 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0160 Revision: C1000000 Serial number: 01140720090171 Coding: 64002000 Shop #: WSC 06335 000 00000 VCID: 005986A8EA0F9D8BEB2-8054 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H25 0380 Revision: 10025001 Serial number: 00000000309692 Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000 Shop #: WSC 01126 444 12187 VCID: 3C213258C667396BF7A-8068 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 100709 H06 0070 Serial number: SWF09070106391 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10537454 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 Serial number: 00000000002906090919 Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B Component: HOMELINK H01 0010 3 Faults Found: 01500 - Bulb for Fog-Lamps; Right (L23) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 196 Mileage: 254546 km Time Indication: 0 Date: 2022.11.25 Time: 17:35:00 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 255634 km Time Indication: 0 Date: 2022.12.18 Time: 12:52:00 02258 - Door Opener Transmitter 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 9 Mileage: 255634 km Time Indication: 0 Date: 2022.12.18 Time: 12:52:00 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 H HW: 8K0 959 655 H Component: AirbagVW-AU10 H37 0520 Serial number: 003EGD027ERA Coding: 303836354230303030304A55304C384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 42DD4CA0A4034F9BBD6-8016 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B Component: BF-Gewichtss. H01 0030 Serial number: 5810000R0900003VYW Crash sensor for side airbag: driver side: Serial number: 6334MSME4942123CA Front Passenger's Side Airbag Crash Sensor: Serial number: 6344MSME49721609C Rear Side Airbag Crash Sensor (on driver's side): Serial number: 6352QSME2433321E9 Passenger side rear thorax airbag crash sensor: Serial number: 6362QSME2F324408G Crash sensor for front airbag: driver side: Serial number: 63732SME5F311E285 Crash sensor for front airbag: front passenger side: Serial number: 63832SME7A2F542EG No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90319IG9000GX Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 3D273F5CDD7D3063C04-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 950 E HW: 8K0 920 950 E Component: KOMBIINSTR. H19 0253 Revision: 00100000 Serial number: BWX365279 Coding: 831F11000300D705020000 Shop #: WSC 06335 123 12345 VCID: 313F136C1125C40354C-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 R HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0101 Revision: GB500049 Serial number: 4900G097048260 Coding: 00C303 Shop #: WSC 06335 000 00000 VCID: 50F976E87AEFAD0B3B2-8004 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 Serial number: 1908337E230609 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb Part No SW: 8T0 035 785 A HW: 8T0 035 785 Component: SG ext.Player H08 0280 Revision: 00000000 Coding: 020302 Shop #: WSC 06335 000 00000 VCID: 392F2B4CC9550C43ECC-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 H HW: 8K0 959 793 D Component: TSG FA H11 0306 Revision: Serial number: 0000009056509 Coding: 011C03204000410001 Shop #: WSC 06335 000 00000 VCID: 45D757BCB5AD78A3984-8010 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG Component: BCM2 1.1 H02 0321 Revision: 00002001 Serial number: 0119909386 Coding: 01260E3A207A441400B0020000000000 Shop #: WSC 06342 123 12345 VCID: 78A9EE48B2DFD54BD32-802C Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719 Component: GTO BF H06 0050 Serial number: 00000000000000150482 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J245 PS133 H06 0041 Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J394 PS228 H06 0041 5 Faults Found: 01403 - Glass-Break Sensors; Rear 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 196 Mileage: 254546 km Time Indication: 0 Date: 2022.11.25 Time: 17:32:46 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 5 Reset counter: 6 Mileage: 254549 km Time Indication: 0 Date: 2022.11.27 Time: 13:19:23 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 5 Mileage: 255409 km Time Indication: 0 Date: 2022.12.15 Time: 12:38:56 01519 - Bulb for Back-Up Lights; Right (M17) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Mileage: 255516 km Time Indication: 0 Date: 2022.12.16 Time: 18:05:09 03233 - Controls for Garage Door Opener (E284) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 255634 km Time Indication: 0 Date: 2022.12.18 Time: 12:52:36 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb Part No SW: 8R0 035 223 F HW: 8R0 035 223 E Component: DSP STD H11 0440 Revision: 00000000 Serial number: 00000000000001 Coding: 0203010102 Shop #: WSC 06335 000 00000 VCID: 2F3B15140711D2F3428-807A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 H HW: 8K0 959 792 D Component: TSG BF H11 0306 Revision: Serial number: 0000009058629 Coding: 011C03205400410001 Shop #: WSC 06335 123 12345 VCID: 44D14AB8BE9741AB8FA-8010 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 194 Mileage: 254544 km Time Indication: 0 Date: 2022.11.25 Time: 11:44:39 ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0090 Revision: 00000003 Serial number: 10000000276997 Shop #: WSC 00000 000 00000 VCID: 34311A78EE37F12B3FA-8060 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 06334 000 00000 VCID: 77ABED74B3C1DA33DA8-8022 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 R HW: 8T1 035 186 R Component: Con3 Sirius H03 0351 Revision: 00000005 Serial number: AUZ5Z6I1242659 Coding: 04020002010285004359070800 Shop #: WSC 06335 000 00000 VCID: 46D550B088AB73BB91E-8012 Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E Component: Display 1 Fault Found: 03157 - Functionality limited due to Communications Disruption 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 9 Reset counter: 11 Mileage: 254546 km Time Indication: 0 Date: 2022.11.25 Time: 16:14:30 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 10000000 Bin. Bits: 00000000 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000101512016 Coding: 010C03204000210001 Shop #: WSC 06335 000 00000 VCID: 42DD4CA0A4834F9BBD6-8016 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 207 Mileage: 254544 km Time Indication: 0 Date: 2022.11.25 Time: 11:44:39 ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000101512013 Coding: 010C03204000210001 Shop #: WSC 06335 000 00000 VCID: 42DD4CA0A4834F9BBD6-8016 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 226 Mileage: 255654 km Time Indication: 0 Date: 2022.12.20 Time: 11:54:49 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 336 D HW: 8T0 862 336 D Component: FSE_256x BT H37 0600 Revision: 00000000 Serial number: 00000005046671 Coding: 0010370 Shop #: WSC 06335 000 00000 VCID: 3C213258CA67396BF7A-8068 No fault code found. End----(Elapsed Time: 01:54, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
