Results 1 to 5 of 5
    Apr 05 2007
    Gasket in trunk drainage channel for outer tail lamp
    Anyone know the part number for the gasket in the trunk drainage channel that seals off the outer tail light? My passenger side outer is getting water intrusion and I realized there is a gasket on my driver side but not on the right
    Edit-- finally found it. It's incorporated into the entire "L" panel. Info for future search reference:
    Description: OUTER. Tail Light Bezel. lamp ASSEMBLY. Light Bezel. Inner. Side cover
    Part Number (Right Side): 4G5-945-254
    today: 2016 A6 Jackal Stg1 E85
    yesterday: 1990 Audi 90 Quattro, 2x B5S4, 2 x B5A4, 1xB7A4, 1x C5A6
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by exorcet View Post
    The gasket is missing from both of mine but I’ve not noticed any signs of water intrusion. Wonder what the install is like, the parts are not very expensive…
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Aug 14 2019
    Tampa
    Assembly/disassembly can be found in the manuals. Join the tag chat group if you’d like to access them
    18 S6
    Apr 05 2007
    Thanks Audisthesia. Just got the replacement part and it's pretty straightforward - a little trim tool underneath to start it and it pops right off (I just used a screwdriver as i wasn't worrying about damaging the one i was removing... that worked fine just be careful. plastic trim tool preferred, obviously).
    I don't think this trim piece does anything with regard to preventing water to lights - purely cosmetic, confirming 2k16A6's statement theirs is missing and no water intrusion.
    Looks like the housing itself isn't watertight. Going to wait and let it dry out the next few days and try silicone around lens/body to see if that helps. If not, looks like OEM replacment is $400-600. Non-Audi branded Valeo P/N 47015 is supposedly the exact same at ~$250 (my tail lamp has Valeo stickers so it's the OEM mfg).
    Mar 25 2020
    Coconut Creek, FL
    I tried silicone, without success. Condensation enters my right outer tail light only after very heavy rain. The sun dries it out within a day or two. Still looking for a long-term fix.
    2013 S6
