Results 1 to 3 of 3
    Established Member Two Rings Nebby58's Avatar
    Jan 19 2021
    Des Moines
    Rear view camera fuse. Error U104C00
    Hello,
    My rear view camera has not worked for quite some time.
    My OBDELEVEN is giving me this fault code. I am attempting to troubleshoot what could be causing this, and I want to check a blown fuse.
    The camera fuse in the manual is not in the car. I was wondering if maybe a different fuse is linked to the camera. My home link is also broken, and I am unsure if this could be an issue as well. Could it be under parking aides?
    2017 Audi A6 C7.5 2.0 TSFI
    Mods:
    • APR Stage 1 Tune
    • APR Coils
    • JH 3" downpipe
    • JH HFC
    • Eurocode Drivetrain Mounts
    • Injen CAI
    • GFB Diverter valve
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    You are looking in the trunk.
    There are three fuse panels Driver's side dash, Passenger's side dash and trunk.
    I believe the one you are looking for is on the driver's side and unfortunately the manuals are notoriously bad for fuse locations.
    In your case I'd look more specifically for the blown fuse rather than trying to find the exact fuse location, but since your Homelink also doesn't work it should likely be A10 (black) which is the right-most column on the driver's side panel.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 19 2021
    Des Moines
    Quote Originally Posted by gk1 View Post
    Thank you so much, I really appreciate this. The diagram was making me go crazy. Going to start pulling them manually!
    Mods:
    • APR Stage 1 Tune
    • APR Coils
    • JH 3" downpipe
    • JH HFC
    • Injen CAI
