Results 1 to 1 of 1
    Junior Member Two Rings
    Jul 24 2013
    Sumner, WA
    mk1 225 manifold-turbo bolt washers
    I have had 2 of my exhaust manifold-turbo bolts back out using stock washers and a flat washer/split washer combo.
    ECS tuning is selling the flat washers for 28$ ea.
    They also have a nut locking flange that would work with hex bolts.
    Anyone successfully switched from the stock reverse Torx 14 bolts to a hex bolt and used the flange?
    Or used any other washer combo that has worked successfully to prevent the bolts from backing out?
    thanks,
