I recently had an oil leak lead to chain tensioner failure im pretty sure. The leak is bad bad. I can see oil on parts behind serpentine on lower part of engine. All oil points backwards and low from then on. What do you guys think it is? I recently replaced oil pan and gasket as well as valve cover gaskets no leaks anymore from those.
