Audi a4 2.0tfsi 200hp -2006 with check engine and p0171
Barely not able to remove oil cap when engine is running beacuse of the vacuum in the engine. Replaced pcv and vacuum pump!! What else could be causing this?
I also got an engine knock from the rear of the engine wich i suppose is the cam chain and tensioner, oil pressure is fine, cam follower replaced...
Thanks in advance!
