Results 1 to 3 of 3
    Jun 05 2022
    Minnesota
    Misfire 2005 3.2 230,000miles a4 quattro
    Cylinder 2 misfires / had vacuum lines on wrong for 5miles. The code came up camshaft sensor . And p0302 is now the only code
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Camshaft Position Sensor was an easy replacement on my prior 3.0 V6 so I don't think it would be much different for the 3.2. You could try switching sensors (there would be one on each bank) to confirm whether there is actually a sensor problem.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Check all the easy stuff air filter ect. I once had a mouse build a nest in my intake box on a weekend and man am I glad I had a good filter in the car.
    not sure if that helps. but always check the easy stuff 1st.
    SOLD the GOINHAM A4 ---> GT2860 Project
