Hey everyone just hoping someone out there could help me figure out the best plan of action for the issues I’m facing with my car. I’ve searched the web, Facebook groups, YouTube and any other forum I could find but I haven’t had any luck so far.
A little background info on my car, I have a 2012 Audi A4 2.0T Quattro. I am currently running a Unitronic Stage 2 tune, modestly modded, 3” catless test pipe, ECS turbo inlet pipe, muffler deleted, throttle pedal controller, new RevD diverter valve, Turbo outlet noise box deleted, Drop in air filter, and I just put in new spark plugs (BKR7IEX NGK 2667). Oils changed every 3000-4000km. Only pump shell 93 octane or chevron 94 gas.
Now the fun part. Car has good days and bad days, some days super fun to drive feels peppy etc. then I have sluggish days where my throttle response is definitely slower (throttle adaptation helps occasionally). But my biggest issue is my HORRIBLE fuel economy. A full tank gets me 155 miles or 250km. I know these cars are heavy and the tank is not as big as my 2.0T Q5 but this is getting expensive. I literally watch my estimated KMs drop by 10km every 5 minutes of driving.
A few factors that might go into play, car has an exhaust leak from the test pipe install (smells horrible if I use the defroster or have the windows down at a red light). Very shitty crush gasket definitely has a leak where it meets the turbo, also it’s leaking from where the downpipe connects to resonator (these are to be fixed) however fuel mpg was trash prior to going stage 2.
Car had a rough idle on cold start and would almost stall so I just put new spark plugs in hoping this helps, old plugs were literally black.. not sure if this is helping as I just filled up a full tank so fingers crossed I see some improvement. The plugs I installed were NGK 2667 BKR7IEX they are one step colder and my gap measuring tool read them to be 0.028 out the box, I was under the impression they were supposed to be 0.032. Do you think I should regap the iridium plugs to 0.026 or keep them at 0.028?
Now a few OBD2 codes from Carista,
Basic OBD2:
P0130 (Permanent) (Pending) (Confirmed) - O2 Sensor Circuit Bank 1 Sensor 1
P0030 (Pending) (Confirmed) - HO2S Heater Control Circuit Bank 1 Sensor 1
P0130 (Pending) - O2 Sensor Circuit Bank 1 Sensor 1
Got this code once:
P0506 (Pending) (Confirmed) - Idle Air Control System RPM Lower Than Expected
Engine:
04010 (Got this once)
02875
07670 (Get this often)
Pic of my car attached :) I’m currently in the process of a B8 to B8.5 front end swap :p
Thanks again ahead of time for any advice.
