TWO used 17.5mm thick 5x112mm bolt pattern, 66.6 center bore, ECS spacers - 002411ECS03B-18. Originally about $50 each. Selling the pair for $SOLD
TWO used 8mm thick 5x112mm bolt pattern, 66.6 center bore, ECS spacers - 002411ECS01B-08. Originally about $40 each. Selling the pair for $SOLD
TEN OEM-length (~30mm) cone-seat bolts, M14x1.5, tuner spline, including socket. Originally about $20 off of Amazon. Selling the set for $10. This is what you need if you bought aftermarket wheels (almost all have cone seat bolt pockets) but aren't running spacers.
TEN +10mm-length (~40mm) cone-seat bolts, M14x1.5, tuner spline, including socket. Originally about $20 off of Amazon. Selling the set for $10. This is what you need if you bought aftermarket wheels (almost all have cone seat bolt pockets) and are running 8-12mm spacers.
ONE extra-long wheel removal dowel. Heavy-duty metal and twice as long as the crappy plastic one that comes with the car. Great for aligning your wheels so you can get a couple bolts threaded on. An absolute MUST USE if you have Carbon Ceramic brakes, but wise for all to employ. $SOLD
ONE tow hook license plate mount. Wasn't liking my low-mount front plate and thought I'd try something new, but it wasn't my vibe so I went back to the low mount. It's basically new. Set it up in basically any orientation or offset you want thanks to the flexible mounting configuration. Lightweight anodized aluminum adapter and powdercoated stainless steel plate mount (as far as I can tell based on weight/appearance... nothing magnetic). Cheapo models go for $30+ on eBay and Amazon. $SOLD
Thanks for looking!
-Jon
