Results 1 to 7 of 7
    Dec 08 2022
    New York
    And just like that....
    Hello all I'm new to forum. I recently purchased a 04 S4 with 112k on her. Motor was replaced at 70k paperwork to provide. Car ran great no issues until other day. I was at a local pub having a pint. Drove a friend into town ( only had 1 pint and it was like an hr before I drove) came back to pub to have 1 more and close tab. Went to start car, won't start. Starts for 1 sec and stubles then nothing end up killing battery trying to start again. What should I be looking for as why she's dead? Car turns over no noises like metal grinding or broken anything. Starter sounds strong Justin will not start. Car has fuel also. Looking for any insight into this issue or where to start looking. Thanks in advanced. PROST !
    Sent from my SM-N986U using Audizine Forum mobile app
    Veteran Member Three Rings Atomic Avant's Avatar
    Jul 11 2016
    2005 S4 Avant, 2016 Q5
    Ontario, Canada
    Any lights on the dash?
    Have you tried a different key/replaced the battery?
    Off the top of my head it sounds like the immobilizer.
    Sent from my NE2215 using Audizine Forum mobile app
    AKA: FlyingNipples
    Dec 08 2022
    New York
    Will try different key ...replaced battery also.
    Senior Member Two Rings alcatranz518's Avatar
    Jun 10 2014
    Stoneville, NC
    Is the tach moving when you crank it over? If the crank sensor went that will cause the problem you are describing. Its easy (somewhat) to get to from the top behind the oil filter.
    Dec 08 2022
    New York
    Shouldn't the tach be moving a lil?
    Jun 10 2014
    Stoneville, NC
    It should be, yes. But if the sensor failed it won't budge.
    Dec 08 2022
    New York
    Figured it out was bad fuel pump.
