    Oct 14 2006
    by the lakeshore, mi
    fix for interior lights?
    The interior overhead lights for the rear seats and the rear avant cargo lights are still not working with new new bulbs installed. Is there a fix to get them working again?
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Are you getting power to the sockets? Do the lights work with regular bulbs? Have you tried reversing the LED’s? They only work in 1 direction.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Oct 14 2006
    I have LED bulbs installed. I tapped on the housing for the cargo lights and the lights briefly turned on then went off. The same thing happened with the overhead lights for the rear seats. So I'm guessing it's a switch problem?
    Nov 13 2009
    I would think it’s a bulb fitment problem. Try your old light bulbs again and see if they work. If they do, then compare the shape of the bulbs and see where the issue is. If it flickered on, you are almost there.
    Oct 14 2006
    I found out why my interior lights are not working properly. Both switches have broken solder joints.
    This switch is for the rear seats.
    This switch is for the rear cargo.
