Since VoltasIT has still not added a service action for doing the battery adaptation, you'll need the PRO subscription to access the Adaptations action for the CAN Gateway. I don't know if you can at least access and view the existing adaptation value without PRO. But go to CAN Gateway, see if you can go into Adaptations, and look for the existing value for adaptation channel 04 (iirc). The important piece you are looking for from that value string is the 10 or 11 character part number. The 10 character serial number and the 3 letter vendor string are irrelevant.
Or you can just look in the battery well and see what type and size battery you have. If it's original, it might have an actual part number right on it.
