Results 1 to 3 of 3
Thread: HPFP gone bad?
    Established Member Two Rings dspl1236's Avatar
    Dec 15 2007
    '90 90q 2.6, '90 GTI 3.6, '12 A6 3.2T
    Akron, Ohio
    HPFP gone bad?
    So I believe my HPFP has crapped out. I kept getting low fuel rail pressure code. today I got an open circuit on the N247 after unplugging and dielectric on both connectors.
    I just wanted to verify with the internet what I am seeing.
    In tank fuel pressure seems to match the rail pressure as I increase rpms.
    Address 01: Engine Labels: 06F-907-115-AXX.clb
    Control Module Part Number: 3C0 907 115 F HW: 3C0 907 115 G
    Component and/or Version: 2.0l R4/4V TFSI 0030
    Software Coding: 0404010A19070160
    Work Shop Code: WSC 66565 257 00032
    VCID: 2345F0A6E2941097F7-8076
    3 Faults Found:
    008852 - Fuel Pressure Regulator Valve (N276)
    P2294 - 004 - Open Circuit
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 316627 km
    Time Indication: 0
    Date: 2022.09.08
    Time: 21:04:54
    Freeze Frame:
    RPM: 852 /min
    Load: 34.9 %
    Speed: 0.0 km/h
    Temperature: 20.0°C
    Temperature: 8.0°C
    Absolute Pres.: 970.0 mbar
    Voltage: 14.097 V
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 -
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 316627 km
    Time Indication: 0
    Date: 2022.09.08
    Time: 21:05:05
    Freeze Frame:
    RPM: 789 /min
    Load: 36.1 %
    Speed: 0.0 km/h
    Temperature: 21.0°C
    Temperature: 8.0°C
    Voltage: 14.351 V
    000769 - Cylinder 1
    P0301 - 001 - Misfire Detected
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 316627 km
    Time Indication: 0
    Date: 2022.09.08
    Time: 21:05:05
    Freeze Frame:
    RPM: 789 /min
    Load: 36.1 %
    Speed: 0.0 km/h
    Temperature: 21.0°C
    Temperature: 8.0°C
    Voltage: 14.351 V
    Readiness: 0110 0100
    Friday,16,December,2022,12:21:53:16872
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 22.3.1.1 (x64)
    Data version: 20220401 DS337.0
    www.Ross-Tech.com
    Address 01: Engine (4G0 907 551 D)
    12:21:51
    IDE00589 Fuel pressure 490 kPa rel
    ENG101818 Actual fuel rail pressure 4988.32 hPa
    ENG99715 Fuel pump: activation 26.659 %
    ENG100489 Fuel pump: actual fuel pressure 5197.93 hPa
    ENG100969 Fuel pump: fuel pressure: I-controller -8.902 %
    ENG100409 Fuel rail pressure: specified 39906.5 hPa
    ENG101692 Fuel supply system: high-pressure regulator 34950.07 hPa
    '13 A6 3.0T + '90 Jetta 2.0T 20v + '92 Corrado SLC + '90 90q 2.6 20v + '90 GTI Plum 3.6 VR6 + '89 200 10vt + '12 A6 3.2T + '01 A8
    Gone: '91 200TQA, '90 V8Qm, '97 A4 1.8T, 2x '98 A4 1.8T, '90 80Q, '90 CQ, '91 CQ, '91 CQ 1.8T, '91 200TQ, '95 90cs, '01 Jetta 1.8t, '08 Passat 2.0T, '13 GLI, '76 Audi Fox, '04 1.8T USP
    Dec 15 2007
    Akron, Ohio
    Yup, bad hpfp. Out in a known good used and its happy again. full fuel pressure to the rail. Back to boost.
    The hpfp swap was almost as quick as a s/c belt swap
    Jan 10 2023
    United States
    I was getting “running lean” and rough idling on my 2015 a6 2T at 6 yrs/120k miles and the HPFP change completely fixed it
