So as the days have turned colder, I have started to use features of the car that had remained dormant.
It appears that my rear window defroster doesn't work. Wondering if there are any common issues that can cause a fault or testing options?
I have checked:
Button on A/C panel lights up when pressed.
Relay in the Pass Side panel in the trunk was swapped for a similar one. Could hear relay click when installed in other socket... no click when installed in the Defroster socket.
Have wandered through OBD11 looking for an output test to manually but cannot find where it can be manually operated. Gateway... Central Electrics...???
Since the switch lights up and the relay doesn't click, I am leaning towards a module, but which one and before diving in that deep are there other options??
Cheers,
KS
