Results 1 to 6 of 6
    Junior Member One Ring
    Apr 05 2019
    Georgia
    Bolt size Coil Pack Wiring Harness Conduit?
    Hi!
    I’m going to replace the Coil Pack Wiring Harness Conduit on my 2.0 FSI. The two little torx(?)bolts are missing.
    Does anybody has the bolt size/pitch or part#?
    Thank you guys
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    It is not a machine thread. It is into the plastic valve cover so the threads are like a wood screw or a sheet metal screw.
    Just find one that is just big enough diameter to grab and make sure it is not too long otherwise you will drive it right thru the valve cover and it will leak oil. And use a washer, the OEM ones have an oversized head.
    They are in the 3/8" to 1/2" length range if i recall.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Older_not_Wiser View Post
    or pierce one of the PCV chambers in the cover
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Junior Member Two Rings
    Sep 01 2021
    Northern Colorado
    Missing mine, getting some are on my to do list but see.
    https://www.audizine.com/forum/showt...ess-Screw-Help
    Sent from my Pixel 5a using Audizine Forum mobile app
    Apr 05 2019
    Georgia
    Thank you all.
    Hr4rge35 on mine it’s definitely not an m6 looks more like m3 but I,m afraid Older_not_Wiser is correct that’s not an typical metric pitch. I might just leave em out. No need to break more plastic.
    Thanks again
    Feb 15 2016
    Cambridge,Ontario
    minor parts like this that irritate me every time Iook at it, I grab from the dealer and be done with it
    1976 Yamaha XS 360
