Results 1 to 7 of 7
    Mar 24 2016
    01 Noggy S4 09 VW CC AWD 3.6L
    westchester ny
    Front crank seal help
    I am installing my front crank seal flange but don't know which bolts go where. When I picked up my block from machine shop they gave me a box of bolts from the engine tear down and now im not sure which ones I need for the flange. If someone has a exploded view from a bently manual that would be best. thanks
    Nov 21 2012
    BC
    Mike has been kind enough to host this for all of us:
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Bentley's Secret Sauce
    -link in 1st post. For some reason I can't just put the link here..
    Sent from my motorola one 5G ace using Tapatalk
    2000 S4 - Daily
    1989 MR2 Supercharged (Turboed)
    Mar 24 2016
    westchester ny
    Wow ppl are awesome and the internet is still undefeated!!Thanks!!
    Mar 24 2016
    westchester ny
    anyone know the part number or size of the coolant drain plug in the front crank flange?
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Quote Originally Posted by wstpride92 View Post
    There is none-
    The only engine drain is at the bottom of the block----
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    That front flange plug is not for coolant.
    The answer is in this thread though: https://www.audizine.com/forum/showt...2#post12822482
    Mar 24 2016
    westchester ny
    Thanks
