The flapper sensor in my brand new S3 already went bad, I talked with the dealer and they were pretty much no help at all, saying they couldn't look at it for a few months so figured I would tackle it myself. I was able to get a replacement sensor and have some picks so was able to get the old one loose, however, I didn't realize the bracket in front of it is JUST in the way.
There are 2 bolts to the left, and the 1 bolt next to the sensor, I am thinking of removing the bolt next to the sensor and then one of the bolts to the left, then loosen the other.
It looks like the bracket is cut out just enough I can rotate it up a few mm to create room for the sensor removal.
Has anybody else tried this or found a better way to get it out (without removing the entire intake)?
Thank you!
https://drive.google.com/file/d/17SU...usp=share_link
