However, are the 19Z calipers a better caliper? You'd think that if you purchased the CCB option from Audi that you wouldn't downgrade in the number of pistons in the caliper. What is your opinion on stopping power of the standard 8-pot caliper with RMR 380mmx34mm rotor option vs the 19Z calipers? Are the 19Z calipers easily installed on a non-CCB version or are any hardware (i.e. brackets) required?
There's a company selling a rear brake upgrade kit which uses an R8 356mmX32mm rear rotor and incorporates a 4-pot caliper from a Porsche Cayenne or VW Touareg and a Tesla E-brake caliper. https://voshmods.com/collections/b8/products/b8
You could technically put the CCB rear upgraded R8 rotor from RMR https://redmistracing.com/ols/produc..._CCB_4-FRN-RTR and have a full CCB upgrade on your RS5.
Now, I know folks will say it's a waste (rear doesn't matter as much as front, etc), this is mostly as a topic of discussion at the possibility, should anyone want to do it that's a bit eccentric. Like me.
Cheers!
