    Established Member Two Rings HibiscusB5_A4's Avatar
    Sep 27 2020
    2001 B5 A4 1.8TQM
    Redlands/Fairfield CA
    17z Fitment Behind 18” USP wheels?
    Anyone managed to fit 17z front calipers behind the B6 USP wheels? If so what spacer provides a good fit?
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    I'm pretty sure I've seen is done, I don't know the specs. and you will need B5 S4 or b6 uprights I believe.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    17Z's will fit behind 17" wheels so 18 is no problem. Just get the right offset and you are done.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    17z calipers with Apikol mounts on my 98 with 17x8 35et BBS LM with a 3 or 5mm spacer. 18's will clear barrel wise, just depends on how the face of the wheel is made.
    1998.5 A4 1.8TQM My Build
    Sep 27 2020
    2001 B5 A4 1.8TQM
    I have the S4 uprights and the 17z’s and all the parts. My concern is installing them and my wheels not fitting. ET43 I believe is the USP wheel. I am thinking I’ll need spacers so might just order some and install them if needed.
