Hi to all forum with my first post. Was falowing this forum since i bought my Audi 5 month ago and get a lot of help. But its time to make a threat because neihter me nor my mechanics figure it out whats going wrong anymore..
so lets start; Note: Problem Solved i left this massage to future users for chekpoints
Audi A4 B7 2007 2.0T FSI Quattro Sedan Manual 6 Speed BWE Engine 200HP at 250.000km. Levoto LPG System installed
What has been done;
(Numbers with "x"means how many times its changed, last brand is final and on the car atm
1x All Spark Plugs (NGK İridium)
1x All Coil Packs (NGK)
1x Air Filter (MAN)
2x Engine Oil 5-40 (LiquiMoly Green)
2x Oil Filter (Man)
1x High Pressure Fuel Sensor (Bosch)
1x Low Pressure Fuel Sensor (Swag)
2x High Pressure Fuel Pump (Pierburg/Hitachi)
1x Cam Fallower (Swag)
3x Low Pressure Fuel Pump (Delphi/Delphi/Simens VDO)
1x Low Pressure Fuel Pump Control Module (Wisco)
1x Camshaft Position Sensor (Bosch)
1x Crankshaft Position Sensor (Bosch)
2x Fuel Filter (Man/Man)(6.0 BAR)
1x Injector on cylinder 1 (OEM Used) (was causing missfire)
1x Main Relays (Under ECU) (Bosch) (I dont have separate Fuel Pump Relay under dash)
3x Throttle Valfe Cleaning
3x İnjector Cleaning + Additive on Tank System Cleaning (LiquiMoly)
1x Secondary Oxygen Sensor B1S2 (Bosch)(was giving error codes)
1x Maf Cleaning (With LiquiMoly Maf Cleaner)
1x All Electrical Sockets Cleaned (LiquiMoly Electrical Contact Cleaner)
2x Carbon Cleaning
1x ECU Rewrite/Reflash to Orginal
Camshaft Lobe is Inspected and no wear its Ok
PCV Valfe İnspected/Tested and its Ok
Presurized air blowned from fuel pump outlet to front rail entry point no debris or clog seen
LPFP bottom filter controlled and its on place
Sender unit on the other side of tank controled and its ok no clog there too
Cheked all Fuel lines by 2 different mechanic...no bending, no damage nothing...
LPFP Control module tested with multimeter acording to audi procedure and its modulating voltage as described (5v on idle to around 7v on wot and back to normals)(car on neutral)
All adaptations done
Problem seen on Live Data;
LPFP Duty cycle is %50 on idle and goes around %95 on demand on road wot
While i falow live data i chek DutyCycle of lpfp, rail presure(low side) and rail presure (high side)
Whats happening is when on wot low presure side continously desending to 2 bar and after 4000rpm its drops below 1.2bar and sometimes less than 1bar (like 0.87bar)
And as soon as its drops under 2-1.5 bar, high presure side also starts declining from 110-120 bar to rapidly 90 50 30 to even single digits like 2bar and car starts to stalls jerks and sometimes enter in limp mode. And Sometimes it cannot recover and stops.
ECU only gives code p2293 low fuel presure regulation
Since i did everything related and cheked every aspect. im running out of options...
Before starting all over again i hope ppl with knowladge help me because this looks like a egzotic problem on my case
What i consider on future;
-T-line just before hpfp maybe cloged?/ Clog on mysterious unseen point?
-ECU cables to pump faulty maybe? (Without a code for it?)
-LPFP Control unit or pump goes out of power on wot? (Without a code for it?)
(Alternator and battery is fine btw)
Maybe take rs4 controller and make a custom map with it? (For a stock car?)
Or change map on deafult controller?? İ dont know even thats possible?
İts looks like my lpfp not delivering fuel nor holding pressure on Wot after 4000rpm witout a reason...
Car is completly fine under normal driving
i running out of ideas.. pls help
