Originally Posted by
Smac770
Scan tools are going to be reading a measuring value or measuring block entry. It should be reporting value 1 from block 18 from the J533 (19-CAN Gateway). That's the voltage reported by the J367 on the negative battery post to the J533 via LIN. But it could be reading block 1 from the J533, or even grabbing the value from the J623 ECM.
12.5 is exactly where it should be. The J533 is going to target 85% SoC, not 100% SoC. Some kind of overcharging safety buffer.
Make sure the battery tester is aware of the battery type. If it's AGM, you need AGM aware tester/charger. Using wet flood stats against an AGM will give incorrect results, and vice versa. Can that tool go to the CAN Gateway and read blocks directly? Battery voltage is one of the values in block 18, computed SoC is one of the values in block 19, computed internal resistance and battery capacity are in block 20.
But those values were done at the jump start posts under the hood? What values are reported if performed at the battery posts themselves?
But back to Carista, it's reading that from a car control module. It's not making up the value. So something in the car is seeing a full V less than what you're measuring?
I'm not sure if you looked at the attached pictures, but it shows the battery type chosen on my tester, which is a flat AGM as opposed to a spiral AGM. I didn't check at the battery....I was too lazy to pull the spare tire out. Either way, my tester only has the ability to connect to the battery/jump posts.....it can't read any blocks directly. It's just basically an electronic battery tester.
As for Carista, I sent them a message through the app and they responded by telling me that "the adapter gets the voltage reading directly from the vehicle when it's connected." I got a kick out of that response, but it's about as vague as possible. I'll see if I can get more info from them. It's definitely far off from the actually battery voltage.
My only concern right now is that I have a one-year-old battery that's giving me less than 300 CCA already, which is less than half of it's rating.
