Results 1 to 8 of 8
    Junior Member One Ring
    Apr 28 2022
    Carbondale, PA
    Stupid newb question
    So my b8 s4 coolant was about 2 quarts low. Dont see a puddle. Most common things to start checking?
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    Worse case is it’s being dumped into the cylinders via the intercooler cores inside the super charger…
    Pulling the supercharger is very easy and only takes a few minutes, this would tell you if they are leaking or not…
    Again worst case.
    Also, are you checking when cold vs operating temp?
    Established Member Two Rings austin1346's Avatar
    Jul 19 2022
    US
    Might be the PCV as it's a common problem. Do you smell coolant while driving? See any white smoke from exhaust while accelerating?
    Apr 28 2022
    Carbondale, PA
    Ok. Operating temp check
    Apr 28 2022
    Carbondale, PA
    I do smell coolant while driving especially when the heat is on
    Mar 31 2008
    eS-4
    CAL*SO
    pull the sc off and look. it sounds daunting but its a really easy 30min job.
    its only being held down by 6 bolts, belt, and 7 sensors. lol
    Veteran Member Three Rings Krusty's Avatar
    Sep 18 2012
    long beach
    2011 sprint blue s4, EC subframe stabilizer, ECS short shifter, Euro Impulse weighted shift knob, custom air intake, RS grille, CR-15, 034 rear diff mounts/rear diff carrier mount inserts, Apikol rear diff mount insert, 10mm(f)/12mm(r), ECS strut tower brace, ECS front adjustable end links.
    Sep 18 2012
    long beach
    Also, if you do this, do not try to flush coolant via the plastic SC screws. If you do, expect them to break and have the 034 billet screws ready to replace them. Make sure you get the OEM coolant refill tool.
    https://www.amazon.com/dp/B01BW39HJS...roduct_details
