Results 1 to 11 of 11
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    S4 B6/7 brake hissing sound
    I hear hissing when I press down the brake pedal, the braking is crap, and my pedal will run to the floor when pressing on it (it won’t do it on its own); I still can stop the car if I pump the brake few times, of course, I'm not driving it.
    Inside: https://youtu.be/0eOV9YQiJrM
    Outside: https://youtu.be/fpmAS1ejD4I
    I Bled the brakes with a power bleeder and the traditional way, with no air or leaks.
    Is it the MC, booster or both?
    Veteran Member Three Rings Atomic Avant's Avatar
    Jul 11 2016
    2005 S4 Avant, 2016 Q5
    Ontario, Canada
    How is your fluid level?
    Sounds like air escaping past a seal in the booster to me.
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    I agree with Nips.
    Weird, though
    I'm still listening for that rattle!
    If it rattles, it's because I baby it.
    B7 S4 25Quattro
    Established Member Two Rings 09SCiduA's Avatar
    Jan 24 2010
    1990 Audi Coupe Quattro S2 Clone
    Bozeman, MT
    You need a new booster...how did the booster lip get marred up; it could be the culprit...? JB Weld that lip or swap it out
    2004 A4 Avant 1.8t 6spd, S4 RSB, 2.0 coil packs, SAIP delete, Bosch 550s, Mountune stg 1.5
    Mar 12 2016
    The land of Kiwis
    Fluid level is ok.
    I thought fluid escaping to the booster and if so I should see some in the vac hose getting sucked in to the manifold ?
    Still if it’s the booster only then why the pedal run to the floor.
    It’s like both failed in the same time > weird
    Jul 11 2016
    Ontario, Canada
    Quote Originally Posted by Dondbg View Post
    Fluid level is ok.
    I mean for the cost and hassle I would just replace both.
    Mar 12 2016
    The land of Kiwis
    Quote Originally Posted by FlyingNipples View Post
    Agree. that what I have in mind since I got a used booster and MC.
    But want to know which one is faulty.
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Probably the booster - the vacuum diaphragm must have a leak. My two cents anyway
    B7 S4 25Quattro
    Mar 12 2016
    The land of Kiwis
    Quote Originally Posted by Zolli View Post
    But that will not cause the pedal to run to the floor, that’s a bad MC.
    I discounted the booster vac hose, plugged thr intake manifold side and started the car, i lost power braking, this tells me it works.
    Mar 12 2016
    The land of Kiwis
    Replaced booster and MC and brakes are back.
    By the look of it. I had a faulty MC.
    Jul 11 2016
    Ontario, Canada
    Glad you got it sorted. Poor braking is nothing to ignore!
    Did you figure out what failed with the MC?
    Sent from my NE2215 using Audizine Forum mobile app
    AKA: FlyingNipples
