Advanced Boost Control System | OBD Reader Multi Gauge
The iboost boost control system is a very new advanced boost control system. When we decided to build a boost controller, we knew we had to offer more capabilities than other products available today, while still maintaining the user-friendly functionality demanded by our customers. Instead of repackaging the same boost control technology that has been used for decades, we choose to pair our advanced sensor control technology with our all-new, proprietary solenoid control that provides superior boost control accuracy, response and safety. We also added a user programmable shift light and housed the entire package in a compact gauge body for ease of installation and use. These controllers the ability to read and report values that other controllers do not, which can deliver more optimized engine tuning and a safer overall operating condition. A boost display gauge and boost controller in one.
Product Description
The Can bus Version Includes (only for cars that support CanBus
Boost Controller
Pressure Sensor
Solenoid
Wiring and Connectors (plus and play install)
Obd Controller
Features
Boost Per Rpm
Boost Per Gear
Boost Warning and Limit
Start Boost for Faster Spool
3 Boost OFF, LOW, HIGH)
Rpm Prepare and Shift light
Exhaust Gas Temperature Warning and Limit
Air-Fuel Ratio Limit Per Rpm
Customizing 12 Volts Output
External Input for Changing Boost Maps
External Input for Safe Mode (Off Map)
Record High Variables
Record High Variables Since Car Start
High Accuracy 4 Bar Map Sensor
IMPORTANT INFORMATION
iBoost recommends resetting the boost set point values to Zero and measure the new minimum boost pressure before increasing your boost set point values.
When the valve working it will make sound.
Shorter Tubes Produce faster turbo spool button.
Further Support
To find out more information visit https://jdyperformance.com
Iboost installation video:https://www.youtube.com/watch?v=nE1eFGe2Kjg
http://https://www.youtube.com/watch?v=-03wPUd_OY0
Consult your qualified installer / electrician for any user queries.
