So the JHM oil cooler kit is bit expensive and I like to DIY my own oil cooler kit. I have a question in regards to the oil ports on the engine block. It looks of course JHM machined a custom plate to install the AN fitting. I called and asked if they can sell just that block and they said, it would quit expensive as they need to take it out of a kit which I can understand.
My question is, I like to tap the 2 oil ports on the engine block to accept an 8AN to 10AN ORB fitting. I measured the opening and the 8AN orb fitting seems to be perfectly size to use a 1/2" npt tap I believe it is what 8AN thread pitch is? Correct me if I'm wrong on that. Now, once I tap the 2 opening, I can install the orb fitting and therefore, use AN fittings to a oil thermostat and now to the an oil cooler mounted in front of the radiator. I can get all the parts on Amazon for fraction the cost of the JHM kit in which should be doing the same function. What you do you think if this? Also, I have been using the Amazon oil coolers for my endurance race car that we do 8 hours races a day for 2 days with practice and quali with success at a fraction of the cost on top brand name oil coolers.
Does anyone know the flow direction of the 2 oil ports on the engine block so I can have the correct oil flow direction because the thermostat is directional of course?
