Results 1 to 22 of 22
Thread: Sunday RANT
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Sunday RANT
    I was about to take the Silver Slug out for the last time---get the thing warm, oil change, then putting it to sleep for the Winter.
    NO START---crank once-nothing, crank twice-nothing....while cranking the third time I notice no movement of the TACH.
    Verified no RPM signal while cranking (Block-1 VCDS)
    The damn CPS is only 2-years old an is an OE BOSCH unit.....Had a similar issue with a 2-year old BOSCH O2 sensor this past summer....
    ANNOYING---don't know who to "trust" anymore....
    Easy fix but pissed off about poor vendor quality.DAMN
    PS- It's now snowing like crazy here...NO zoom zoom 'til SPRING!!!!!!!
    Veteran Member Three Rings q20v's Avatar
    Nov 12 2014
    2001 Audi A4, 2001 Audi S4, 1988 BMW 530i
    Ottawa, ON
    That sounds frustrating for sure. Especially when you pony up for the OE stuff 😔
    2001 Audi S4: OE K04 / E40 / 3.65s FATS / Maxpeeding Rods / SRM Intercoolers / Catless DPs + Borla Exhaust / 83mm MAF / 630cc Injectors / Walbro 450 / 2.0T Coils / B7RS4 Clutch + TTV Flywheel / 4:1 Diff Shims / Big Brakes / H&R Coilovers / 034 Rear Sway...
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    My tach doesn't move while cranking. Never has lol.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    May 10 2018
    MA
    Sunday RANT
    See my thread you may have other issues, like I did. Same symptoms
    Apr 08 2013
    Connecticut
    Quote Originally Posted by CELison View Post
    Mine barely moves if all is well---have to look real closely.....
    RMode---I purchased a new CPS and will pretend I didn't read your message.....
    May 10 2018
    MA
    Quote Originally Posted by LJS View Post
    Good luck!
    I ordered one late Friday night too - advance locally had the Bosch in stock. By last night, I cancelled it :) I’ve got a bunch more pictures of what I found on my IG stories.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    FWIW: The factory wiring in that area takes on a lot of heat and gets damaged often…I’d push the boot back and take a look, issue could be that and not sensors.
    Apr 08 2013
    Connecticut
    Thanks for the input Guys!
    The sensor is dead----there's a open between pin-2 and pin-3 on the sensor-The Hall-effect switch isn't hall-effecting....
    I also checked the wiring from the sensor plug to the ECU --Pin 108, 82 and 90...all good.
    FWIW- I use this heat sleeving on the entire length of the sensor wiring and boot, at the tranny-
    https://www.thermotec.com/product/ex...eve-thermo-tec
    I'll post an update when I receive the new sensor.
    May 10 2018
    MA
    Awesome
    Yes I plan to do a thermo barrier and fire sleeve. I’m not going through this bs again lol. Multiple wires were well done.
    Apr 08 2013
    Connecticut
    Quote Originally Posted by RMode View Post
    Awesome
    I was looking through your build thread and my heart sank when I saw the condition of those wires---DAMN!!!!!!
    QUESTION- where are you getting the open barrel pins for the CPS---I want to relocate that connector as it sits so close to the turbo exhaust...
    Trying to be proactive here.
    PS- I used some 9FT of the heat sleeve during my build and unless you put your nose down at the firewall, by the air-box, behind the Y-pipe and under the coolant reservoir, you can't see any of it.
    The only downside to the stuff is the cost....considering what it saves in future headaches it's well worth it.
    Apr 08 2013
    Connecticut
    This pin
    Sent from my SM-A505U using Tapatalk
    May 10 2018
    MA
    1J0-973-723-G
    Yep it is expensive, but the way I figure - cheaper than the tow truck was
    Nov 13 2018
    Ocean city NJ
    QUESTION- where are you getting the open barrel pins for the CPS---.
    The terminals are the common Junior power terminal type. Mouser or similar will have them the cheapest if buying a decent amount or if you need a few https://www.bmotorsports.com/
    Is a good spot to purchase from.
    FWIW: I finally caved and bought a professional Rennsteig crimper with appropriate dies for JPT, Micro TimerII, and the Ecu terminals. So if you need any crimps done I can make some pigtails. Just LMK I usually always have the terminals in stock along with most connectors.
    Apr 08 2013
    Connecticut
    THANKS for the connector and terminal info----
    I made a note for the https://www.bmotorsports.com/ location so I'm not asking stupid questions AGAIN
    Aug 06 2008
    Canadia
    Thats because Bosch stuff is now made in Chi-nah, gotta specify you want made in germany if its even available.
    Apr 19 2022
    Cactus Green '99 A4 Avant TQMS Project, '00 E39 BMW 540i6
    New England
    I would advise to check a lot of other things. Timing errors can often be totally ambiguous when reported by the ecu. I had an 'open or short to plus' error. Ended up being the shitty Chinese made behr coolant reservoir leaking through the level sensor connector and wicking up to the ecu. I know, right? Resulting in corroded pins on the ecu.
    Although if you measured open on the sensor then that's likely actually bad.
    Sent from my Pixel 5a using Audizine Forum mobile app
    May 10 2018
    MA
    Quote Originally Posted by MacDaddy View Post
    It really doesn’t matter ultimately. I replaced the crank sensor (under warranty) on my first S4 when the car had 12k miles on it.
    Apr 08 2013
    Connecticut
    Replaced the CPS this morning....all good.
    Here's the 2 year old defective sensor....
    Interesting.....
    The replacement Bosch sensor was labeled made in Germany
    Apr 19 2022
    New England
    Here's the 2 year old defective senor....
    Interesting.....
    The replacement Bosch senor was labeled made in Germany
    Interesting. There are also different versions of the sensor. Pre '00 cars (at least for 1.8ts) have a taller and more angled sensor, later cars have a short, straight (connector bit?) and the connector at the firewall is different. I'm still running my original because I couldn't find an OE sensor. Only aftermarket.
    Glad you got this resolved.
    Apr 08 2013
    Connecticut
    PS- decided NOT to relocate the connector as the wiring from the engine harness is shielded and I don't wish to introduce a "noise" issue with the signal
    Apr 08 2013
    Connecticut
    Quote Originally Posted by cactus_cars View Post
    THANKS-
    simple fixes on this platform are rare....
    Apr 19 2022
    New England
    THANKS-
    Lol. I had a corroded ecu pin causing a crank position sensor error... That took a few weeks to figure out... Not always so lucky.
    All thanks to the poorly made-in-china behr coolant tank
