Results 1 to 10 of 10
    Veteran Member Three Rings Maitre Absolut's Avatar
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    Audi Connect stuck in 3g
    This is for Canada folks
    Everything was working perfectly until 3 days ago when I noticed the MyAudi app stopped connecting to the car "vehicle status could not be retrieved / vehicle communication error".
    In the car I noticed the connection is 3G (Im pretty sure it used to say LTE). And my profile now doesn't have my account linked and when I try to log in it says could not establish connection.
    Anyone else have this problem and how to fix
    2023 RS6 | GW / ER | CTS res delete | Ghost links | H&R 10/12
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    I'm assuming you've tried the obvious phone related "fixes" like killing and restarting the MyAudi app, restarting the phone, toggling cellular data services, etc?
    FWIW, Audi Connect is glitchy as heck. I've had numerous instances of odd behavior including suddenly "disconnecting", causing me to have to go back to the dealership to be reverified. Sometimes sending an address to the car works immediately, other times it's delayed, for days even! I'm currently am waiting for an address I sent two days ago to be received by the car.
    Not sure if this is related, but my Favorites will periodically disappear, forcing me to re-favorite all the SiriusXM stations I'd set up. Other customizations like saving MMI button layouts also don't ever stick following a vehicle restart.
    Every time I get into our 2019 RS5 with the scroll wheel I find myself wishing the RS6 had it as well. In some ways the all touch MMI is better, when switching back and forth between different audio sources for example. I stream a couple Seattle area sports radio stations, but detest commercials and will immediately change audio source to avoid them. I'll switch to satellite for music or to a podcast app then back again. This is far easier to do with the touch screen.
    On the other hand, I miss the physical memory buttons that are in the RS5 for quick switching between radio stations. I also much prefer the manual climate controls over the touch screen.
    In general, the touch screens are hit and miss for detecting a selection. I often have to try to hit a touch button more than once to get it to respond. I've gotten used to the all touch MMI now, but would prefer a hybrid system.
    One last nit, a lack of small storage area under the climate controls in the RS6. I keep a pair of sunglasses there in the RS5. I had to put a tacky rubber mat on the "shelf" right above the MMI to get a similar storage spot. It isn't the most secure of course and I've had the glasses come shooting off the dash when I've floored the accelerator. I know there are other solutions, like replacing the OH S***! handle with a sunglass storage space. I bought the kit even but haven't bothered to install since I suspect most sunglasses won't fit.
    Anyway, supposedly there is an MMI Firmware update either available or coming soon. I have an appointment with Audi Escondido next week where I hope to have these issues resolved...
    Sorry for the digression and minor thread hack to vent...
    Cheers
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    Quote Originally Posted by pwdrskr View Post
    Cheers
    its not my cell phone, that is working fine. Its the car's internet connection that is stuck in 3g which doesnt seem allow Audi Connect to function properly.
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Is there a coverage issue? Does the car switch to LTE in other areas?
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    Quote Originally Posted by FBAnder View Post
    no matter where I drive it stays on 3g now. myAudi hasnt been updated in 5 days so its never gotten LTE since then. It was working perfectly since day 1 (granted that was only a month ago!)
    Someone on the FB group said there's an antenna recall but I haven't found anything online about that.
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by Maitre Absolut View Post
    Ah, sorry, missed that detail. Have you tried a hard reboot of the MMI by pushing on the volume knob for ~20 seconds until the system reboots? That is what I'd try if it were my cell phone with the issue.
    Here's a thought, which cellular network is the car connecting with? ATT, Verizon, T-Mobile? I have no idea anymore. Is the provider different from your phones? Not sure that would matter, however, I briefly switched to T-mobile and suddenly nobody could reach me at home. I'd suddenly get a notification I had a voice mail. Phone never rang. I noticed the connection would bounce around between LTE, 5G, and 5G Ultra Wide too. After a couple weeks of that I went back to Verizon. Anyway, point is, could some similar be happening with your car's cellular provider?
    After that, maybe it's a hardware problem?
    ...or maybe I should stop since I'm not an engineer or cellular connection expert.
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    FYI issue resolved after many back and forths with the dealer, who wouldnt initially take the car in saying its a server issue on Audi side and would resolve itself, and Audi Canada saying everything is working correctly on their end.
    Dealer took the car in yesterday. Issue was with controle module for emergency call and communication unit. Seems like removing/changing its battery worked.
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
    Junior Member One Ring
    Apr 17 2021
    Toronto, Canada
    Funny enough I had the same issue and when brought to the dealer, the same module wasn’t working properly. They reset everything and it was good. I’m back the LTE!
    My biggest issue is that I like to have the heated steering wheel shortcut in the lower climate bar but everytime I turn off the car then get back and start it, it never saves it. I gave up on the system. Hopefully the dealer will take a look again when I bring it in for service next time.
    Current:
    '21 Mercedes S63 Cabriolet - Canvasite Blue (Matte PPF finish)/Porcelain
    '15 Porsche Cayenne Diesel - Carrera White/Bordeaux Red
    '21 Ford F-250
    On Order:
    2021 Audi RS6 - Glacier White/Black w/Express Red Stiching
    2021 Lamborghini Urus - Bianco Icarus/Rosso Rea
    Jul 21 2015
    Your issue is eerily similar to the one I'm experiencing. I have tried resetting everything and still no dice. Next step is the dealer I guess.
    As a side note, anyone think the dealer will install the ASS module for me when the fix the recall of that module potentially being exposed to moisture?
    Feb 04 2010
    Ottawa, Canada
    no SOS, says its on LTE but no Data/No Audi Connect, etc. Came from Audi this way from Day 0. Dealer ordered new J949 part. back ordered with no ETA. Picked the car up brand new with issue.
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance w/AWE SwitchPath, CETE Lowering Mod, 034 Sways, etc
